Old 08-03-2011, 06:21 AM   #1
Brother A
Brother A's Avatar
Default Position of Rumble step on fender
I'm about to install the rumble step of the fender of my 68-C. To my eye it looks like the step should be lined up with the center-line of the wheel and about 4.5 inches from the rear quarter panel to the center of the bolt hole. I would appreciate it if you guys could let me know if that's about right before I take the drill to it. Thanks
Steve
Brother A is offline   Reply With Quote
Old 08-03-2011, 07:53 AM   #2
LeRoycoupe/N.Y.
Default Re: Position of Rumble step on fender
Steve, See How to Restore Your Model A Volume 3
page 126 Tom
LeRoycoupe/N.Y. is offline   Reply With Quote
Old 08-03-2011, 08:06 AM   #3
Brother A
Brother A's Avatar
LeRoy,
Thanks but I only have Volume 6. There is a good picture of the fender step on a 68-C on page 132. That's what I used for my eye ball guess.
Old 08-03-2011, 12:20 PM   #4
FL&WVMIKE
FL&WVMIKE's Avatar
Brother A .....................
Put the fender on the car and make sure to mark the dead top. No matter what dimensions, people send you, if it's cockeyed, it's going to be cockeyed !
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 08-03-2011, 01:45 PM   #5
Brother A
Brother A's Avatar
Thanks Mike. I did exactly that. It's right in the center to my eye.
Old 08-03-2011, 02:33 PM   #6
Kevin in NJ
I did my Albrect repro fender on my 68C. There were dimensions in one of the books which kind of ball parked the position. I had to move the step plate towards the middle of the body some to get it to the flat portion of the fender. The step plate must lay flat all around. I also stepped back and made sure it looked right.
Kevin in NJ is offline   Reply With Quote
