#1 |
Just had to know what that black vacumn looking cylinder was that is attached to frame next to steering column on the 36/5W for sale (for 47,500) Seller sez it is a factory oil filter ???? I never had seen one installed like that.
Ralph |
#2 |
That oil filter was a dealer installed option through 1939. The entire canister was replaced with a new one when it came time to change the filter. Pretty rare item if complete with original hardware. Starting in 1940, Ford used the type of oil filter we are all most familar with.
#3 | |
Finding the hoses are a problem.
#4 |
The oil feed line came off the back of the block next to the pressure sender and the return line had a banjo fitting on the end which replaced the outside fuel pump bolt to the fuel pump stand. The 37 stands, and maybe other years too, are drilled through on that side to allow the oil to piddle back down the stand into the block. These cannister filters were also used on Ford commercial vehicles like trucks, buses and tractors. I have a couple of NOS filters in Ford tractor boxes. At the old Vintage Auto Parts store in Woodinville, WA years ago they had an NOS cannister filter setup for a V8 60. Its bracket was slightly different than the 85, but everything else the same. |
