Old 05-19-2011, 08:15 PM   #1
Max
Default Stromberg 97
Any ideas where I can buy the part that fits on the drivers side of the throttle shaft that acuates the hand throttle? Mine just has a short linkage which pushes the hand thottle knob in and out as you work the accelerator pedal.
Thx,
Max.
Max is offline   Reply With Quote
Old 05-19-2011, 08:21 PM   #2
f1builder
Default Re: Stromberg 97
i think i have an extra one, you do mean on the fuel inlet side, on the carb base, right? if you will PM me your email address i can get a pic and get back to you.
george
f1builder is offline   Reply With Quote
Old 05-19-2011, 08:37 PM   #3
Max
PM sent.
yes its the gizmo on the throttle shaft I am after, left or drivers side of the car, same side as fuel inlet. It is a different fitting to the Holley 94 Carb.
Old 05-19-2011, 08:44 PM   #4
uncle max
uncle max's Avatar
Originally Posted by Max View Post
PM sent.
You'll need the lever, cap, spring and pin.
When you go install it, it's a good idea to support the end of the throttleshaft with a block of wood so you don't risk bending the end of the shaft.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 05-20-2011, 01:09 AM   #5
ken ct
You got it max,i have them also,consistes of the 4 pcs mentioned. ken ct
ken ct is offline   Reply With Quote
Old 05-20-2011, 02:34 AM   #6
ventilo
a need one of these sets as well to complete my new Stromberg 97
ventilo is offline   Reply With Quote
