Old 05-06-2011, 07:06 PM   #1
Bob Grieb
Bob Grieb's Avatar
Send a message via Yahoo to Bob Grieb
Default Engine Fan Repair
I have a question about the feasability of repairing the engine fan. In cleaning parts removed from the old engine I found that the fan had corrosion on the inside surface of one of the blades. After removing the rust I found that the blade itself is hollow. I thought of repairing it with JB Weld but I have some concern about balance (The damaged area is about 1 '' X 1/4 ''). Not being familiar with the Model A engine I am wondering if balance would be a significant concern.
Thanks in advance for your thoughts/help
Bob
Bob Grieb is offline   Reply With Quote
Old 05-06-2011, 07:22 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Engine Fan Repair
Don't even think about it. Replace it with one of the aluminum ones available from the vendors. Reason: it could separate at any time, taking out the radiator, hood sides, you or a loved one if standing nearby IF it decides to "blow" apart. Do a search for other people's experiences and photos.
I'm sure others will chime in on your question.
Paul in CT
Old 05-06-2011, 07:33 PM   #3
Philip McCarty
What ever you do Listen to Paul. Do not attempt any repairs. It is junk.
Philip McCarty is offline   Reply With Quote
Old 05-06-2011, 07:33 PM   #4
Gary WA
Gary WA's Avatar
DISCARD!!!!! Wall Art.
www.whidbeymodelaclub.com
Old 05-06-2011, 07:46 PM   #5
Fred K-OR
Fred K-OR's Avatar
Believe the above comments!!! Fans are cheap compared to radiators, hoods, your head, etc..
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-06-2011, 07:54 PM   #6
Bob Grieb
Bob Grieb's Avatar
Thanks for the input. I was concerned about balance and never considered the safety issues. I really appreciate the advice and I will buy the new fan.
I am very thankfull for the help reveived
Bob
Old 05-06-2011, 08:21 PM   #7
Bob C
This is what it will look like if you keep running it. The other
piece will be in your hood or radiator.
Old 05-06-2011, 08:28 PM   #8
Bob Grieb
Bob Grieb's Avatar
I think you are saying been there done that.
