Old 05-15-2026, 02:44 PM   #1
fordfixer
Default Cotter pins
Just wondering what people are using for cotter pins inside the engine. I have another car in the shop for connecting rod failure, do to failed cotter pins.
Everything I can find is made in China.
fordfixer is offline   Reply With Quote
Old 05-15-2026, 03:36 PM   #2
stevests
stevests's Avatar
Default Re: Cotter pins
There are several "Made in USA" cotter pin suppliers - use Google.
stevests is offline   Reply With Quote
Old 05-15-2026, 06:30 PM   #3
ModelA29
ModelA29's Avatar
Orig castellated nuts only use about 4 full threads. Get some ARP 300-8333 nuts and forget the cotter pins.
ModelA29 is offline   Reply With Quote
Old 05-15-2026, 06:32 PM   #4
Big hammer
Aircraft supply companies should have stainless steel cotter pins .
get a bigger hammer tap done
Old 05-15-2026, 08:02 PM   #5
Brad in Germany
Brad in Germany's Avatar
Only use genuine Nettlefolds cotter pins for Ford cars:
Brad in Maryland
PS: Good luck finding them however.....
Brad in Germany is offline   Reply With Quote
Old 05-16-2026, 05:13 AM   #6
nkaminar
nkaminar's Avatar
The stainless pins that Big Hammer introduced are also available at McMasters-Carr. Those pins are twice as hard as the usual steel pins.
nkaminar is online now   Reply With Quote
Old 05-16-2026, 10:22 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
Cotters are available at Bolt Depot also. https://boltdepot.com/Cotter_pins
Old 05-16-2026, 11:11 AM   #8
J Franklin
J Franklin's Avatar
Even where I would use cotter pins, I use blue LockTight as insurance.
Old 05-16-2026, 11:46 AM   #9
katy
katy's Avatar
Why do cotter pins fail?
Old 05-16-2026, 04:00 PM   #10
bobbader
Fordfixer, hard to imagine a cotter pin failing if properly sized and properly installed. Before we all start dropping our oil pans to investigate, can you relate the failure and ensuing issue you experienced. Thanks.
bobbader is offline   Reply With Quote
Old 05-16-2026, 04:43 PM   #11
old31
Oh, dont talk to me about broken cotter pins. I found this on the bottom of my oil pan one day.
File Type: jpg connecting rod cotter pins bottom of oil pan.jpg (22.3 KB, 83 views)
Old 05-16-2026, 06:57 PM   #12
mcgarrett
A few things I can think of are: inferior metallurgy resulting in premature metal fatigue, incorrect size pin required for application, improper installation, loosening of nut causing a shearing effect on the pin, installing a used pin, and centrifugal force acting against all of the above. There are probably other factors also.
mcgarrett is offline   Reply With Quote
Old 05-16-2026, 07:00 PM   #13
Synchro909
Synchro909's Avatar
This is a cotter pin!
https://en.wikipedia.org/wiki/Cotter_(pin)
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 05-16-2026, 07:05 PM   #14
nkaminar
nkaminar's Avatar
Old 31, Those are not cotter pins (as Synchro would say, split pins) but pieces of round wire. They look like pieces of safety wire. They look like they were twisted together at some point.
Old 05-18-2026, 10:04 AM   #15
old31
NK, you are 100% correct. I never picked up on that; I just assumed that they were cotter pins.
OK, where in the hell did twisted wire come from? Geeeez.
Old 05-18-2026, 10:17 AM   #16
David in San Antonio
David in San Antonio's Avatar
The Wretched Roadster had the bottom few turns of the broken-off oil pump spring sitting in the bottom of the pan. Amazing how these engines will tolerate certain types of degradation without stopping.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 05-18-2026, 10:42 AM   #17
Y-Blockhead
If only we knew the secrets these Ol' Girls hold...
Old 05-18-2026, 10:57 AM   #18
cadillac512
cadillac512's Avatar
Well ya know...back on the farm when we didn't have cotter pins we used baling wire. That picture sure looks like it may be just that. On a rod nut it's less than ideal though!
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 05-18-2026, 01:16 PM   #19
nkaminar
nkaminar's Avatar
100% original Model T's were found to have nails used instead of cotter pins in various places. There was a lot of pressure in the early days to get the cars out so an assembler would grab whatever worked.
Old 05-18-2026, 01:31 PM   #20
john charlton
john charlton's Avatar
The GKN advert the " Birmingham" is big English city not the one in AL .In UK cotter pin is also known as "split pin" .
John in rain showers Suffolk County England
john charlton is offline   Reply With Quote
