#1 |
I have not been able to get the vacuum advance on my '56 Y-block 292 to seal at the distributor diaphragm end. I'm pretty sure that it's the fitting at the that's buggered up. It looks similar to a brake line fitting but smaller. Threads are 3/8-24. I've combed the parts store but they all seemed mystified by it. I know that I don't have a flair tool that I could use on it so I'd need to find one that has the line already fitted to it. Can anyone suggest where to look? I've hopefully attached a photo of the fitting but can't be sure.
Thanks, Tom /Users/thomassanborn/Desktop/IMG_6109.jpeg |
#2 |
That is a fitting that Ford used in all its vacuum connections , at least in the early to mid 50's. It is commonly called a Ford fitting if I remember correctly. CASCO shows the fitting in their catalog. # 35112S - Fitting Vac Adv Line at vacuum advance. Most likely the other old car parts people have it. CASCO also sells vacuum lines with that fitting included.
#3 |
