Old 05-09-2026, 10:53 AM   #1
[email protected]
Default 37 Flathead oil leaks
Excessive oil leaks that appear to be front of engine ( not from cotter key hole) any easy fix, I plan to increase viscosity ( 20/50) and I put on a new breather, should I put on a PCV ?open to suggestions,37 cabriolet is 98 % original open to suggestions
ranrou1@cox.net is offline   Reply With Quote
Old 05-09-2026, 10:45 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 37 Flathead oil leaks
Cover your distributor with saran wrap and give your engine a bath, then get back to us with exact location and amount of leakage. 20/50 sounds good in any case.
Alan
Old 05-10-2026, 01:07 PM   #3
Ggmac
I would not recommend pcv . The 37 uses no rear seal so youd be sucking dust from the clutch area using a pvc
Ggmac is offline   Reply With Quote
Old 05-10-2026, 01:08 PM   #4
Ggmac
You need to do as suggested. Clean the motor and be more specific, picture will help
Old 05-10-2026, 01:12 PM   #5
mcgarrett
Maybe start by tightening the bolts on the oil pan, timing gear cover, distributor, etc. and see if that makes any difference.
mcgarrett is offline   Reply With Quote
Old 05-10-2026, 05:44 PM   #6
mfirth
What mcgarrett said x 2, but do not over tighten the pan bolts.
mfirth is offline   Reply With Quote
Old 05-11-2026, 01:55 PM   #7
1956 ford
A 20/50 is no more then a 20 thought all operating temp go to a 30
1956 ford is offline   Reply With Quote
