Old 05-06-2026, 09:55 AM   #1
Feathercraft56
Feathercraft56's Avatar
Default Curved vent/oil fill tube for 59AB
Good morning all. I am looking for any information on a curved vent/oil fill tube. I'm installing a 59AB motor in a all stock 1934 fordor sedan. The motor has to be lifted in the front some and the clearance between the firewall and the oil fill tube is very close with the stock motor. Raising the motor Think will hit the oil fill cap or make it very difficult to remove the cap.
Any help in the matter would be greatly appreciated...
Kind regards
Feathercraft56 is offline   Reply With Quote
Old 05-06-2026, 10:31 AM   #2
Zax40
Zax40's Avatar
Default Re: Curved vent/oil fill tube for 59AB
Have you considered using a Canadian 59A intake with the front oil fill?
Zax40 is offline   Reply With Quote
Old 05-06-2026, 10:33 AM   #3
Bruce_MO
Some V8-60 motors had a fill tube that leans forward. Not sure about the diameter though.
Maybe a muffler shop could make something that’ll work???
Bruce_MO is offline   Reply With Quote
Old 05-06-2026, 10:37 AM   #4
Tim Ayers
A couple of options:
I had a local muffler shop make me one and I flared the top. Cost about $20.
Find a Lincoln Zephyr V12 vent/oil fill. I forget which year, but these were bent forward from the factory.
Gear Drive sells a cast aluminum one for $80 plus shipping.
https://www.lakeheaders.com/products...ffset-breather
Old 05-06-2026, 10:38 AM   #5
Tim Ayers
V8 60 is too small diameter. I have one. I think the V8-60 is like 1" or 1.25" OD and the V8 is 1.75" or maybe 2". I forget from memory.
My vote is muffler shop. This way you can make it the length you want/need.
Old 05-06-2026, 03:00 PM   #6
Feathercraft56
Thank you for the suggestion.
David
Old 05-06-2026, 03:45 PM   #7
cas3
I just put a taller, straight aluminum pipe in mine.
File Type: jpg FB4A4976-292D-4147-BE3C-B2B60316810F.jpg (77.5 KB, 134 views)
Old 05-06-2026, 06:41 PM   #8
petehoovie
petehoovie's Avatar
Old 05-09-2026, 08:32 AM   #9
Bored&Stroked
Bored&Stroked's Avatar
In my first 34, I installed a 59AB style engine and just made a longer fill tube as shown by the poster up above. Worked out great!
