Old 05-03-2026, 01:01 PM   #1
The Geezer
The Geezer's Avatar
Default LED Headlight Bulbs Question
Has anyone tried the new LED headlight shown as "A" below?
I already have the one shown as "B" below.
I do a lot of night driving, coming back from car shows here in Florida and the LED bulbs (B) that I have work OK, but are no able to be focused.
I am interested in the new focusable ones (A), but would like some pros and cons from FordBarners who have experience using them. Don't want to spend the big bucks unless they get a high rating.
Regards to all - The Geezer
“Finally driving a car older than me!”
The Geezer is offline   Reply With Quote
Old 05-03-2026, 01:27 PM   #2
Keith True
Keith True's Avatar
Default Re: LED Headlight Bulbs Question
I have bought 12 of them.four sets for myself,and two pair for others.I would throw rocks at the others now.They do take a bit of education.When they say,focus,they really mean leveling.That lamp puts out the beam with a definite straight top line,or border.You loosen the screw in it and twist it to level the beam.Allowas for crooked headlight positions.They don't 'focus',as the old bulbs had to because they don't use the reflector for anything but a holder.They don't catch the light particles and bounce them out the front in the correct direction.Their beams are already focused to send out the front.You DO have to aim them correctly though,and if you try to aim them at the wall at the height you would have with the old ones,you will blind people.You can't aim space age lamps using oxcart methods.The inspection stations here have to have the machines for aiming LED lights.I went to a friends garage and aimed mine with his machine.Then I shined them on my garage wall where I have been aiming truck lights for over 40 years,and has lines and crosses marked all over it.The correctly aimed lights on all my A's hit that wall at about knee height.Correctly aimed you will not blind people on low beam,but high beam is another story.You WILL learn to pay attention to your beams,the cops WILL remind you.I do know a couple of guys that are using the flat ones,and like them,but that's because they are cheaper than me and I gave the lamps to them.
Keith True is offline   Reply With Quote
Old 05-03-2026, 01:30 PM   #3
GPierce
GPierce's Avatar
I have them. They work as advertised. Big improvement over the earlier led bulbs that replaced the incandescents. Being focused you don’t need the polished reflectors. Your rusty reflectors work fine with them.
GPierce is offline   Reply With Quote
Old 05-03-2026, 01:46 PM   #4
The Geezer
The Geezer's Avatar
Thank you both for your replies. 2 positive experiences are good enough for me!
FordBarners ROCK!
Thanks again, The Geezer
Old 05-03-2026, 01:54 PM   #5
P.S.
Here is a video comparison, so you can see your A example head to head with your B example- https://www.youtube.com/watch?v=VvbNY2s3Egs
It also shows LED vs. incandescent type.
2024-2026 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 05-03-2026, 02:13 PM   #6
TomInCologne
TomInCologne's Avatar
just make sure you have perfect electrical connections, otherwise they start flickering which drove me mad
TomInCologne is offline   Reply With Quote
Old 05-03-2026, 02:40 PM   #7
The Geezer
The Geezer's Avatar
Paul Shinn's video convinced me that the LogoLite's bulbs are the way to go.
Thanks Paul and Tina, for all you do for us.
Old 05-03-2026, 03:09 PM   #8
P.S.
Glad to be of help!
Old 05-03-2026, 07:41 PM   #9
Ayers1
Ayers1's Avatar
I have 3 sets of Logo Lites and wouldn't use anything else. Definitely an improvement! One other good thing to note, if you're still using an original generator, with the LEDs you should be able to adjust the output down some.
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Ayers1 is offline   Reply With Quote
Old 05-03-2026, 07:57 PM   #10
David in San Antonio
David in San Antonio's Avatar
Another happy Logolite user here. The first set I bought a couple of years ago for my Roadster. They came in a box with the Logo Lite marking. The most recent set, for my newly acquired Fordor, did not have the Logo Lite markings and no instructions. The units themselves appear identical and work great.
One other benefit: they draw so little current the ammeter barely moves when they’re turned on, compared to the big deflection using incandescent lamps.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 05-03-2026, 09:05 PM   #11
CT Jack
CT Jack's Avatar
Without getting super technical, the basic difference between an LED lamp versus an incandescent is the light emitted by the LED is very directional whereas the emitted light from an incandescent lamp is random. The original parabolic reflectors were shaped to reflect and focus some of the light emitted by the lamp. As noted in previous posts the relectors are not needed when using LED lamps.
CT Jack is offline   Reply With Quote
Old 05-04-2026, 09:26 AM   #12
P.S.
Add to this- The reflectors are not needed when using the pre-focused LED lamps. If you use the other style of LED lamps, the reflectors are vital.
Old 05-04-2026, 12:43 PM   #13
Y-Blockhead
Y-Blockhead's Avatar
Normally I would say to support our vendors but you can get the same bulb on e-bay for ~$18 cheaper per bulb. That is a $36 savings. https://www.ebay.com/itm/365229742385?var=634916702511
Old 05-05-2026, 12:46 PM   #14
Mike1291
Mike1291's Avatar
I can confirm that this is the same item I bought to see if they were identical to the Model A suppliers. Slightly different box but same exact part and brand. Get the 5000k; even though it's not the same color as incandescent the other ones are like the old French yellow headlights.
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 05-05-2026, 01:12 PM   #15
The Geezer
The Geezer's Avatar
Thank you to all who responded. My order from LogoLites is coming in today and I will be putting them in and adjusting the levels. Can't wait to see the difference on the road.
Regards to all FordBarners from The Geezer...you all make a difference!
Old 05-05-2026, 11:04 PM   #16
serocontra
serocontra's Avatar
I got B, and while they do heavily reduce the amount of amps i use, i dont see any difference between normal and bright lights.
so i feel like i just wasted money, honeslty.
Archeo-Tech Priest of the Cult Mechanicus.
serocontra is offline   Reply With Quote
Old 05-06-2026, 07:52 AM   #17
old31
I originally bought the B. I liked them much better than 32/50 bulbs. I then bought the A's and liked them much better than the B.
Old 05-06-2026, 10:10 AM   #18
P.S.
FYI- Tina Shinn ("Model T") will be doing a seminar all about the various types of LED lights for the Model A's at the MAFCA NCRG Roundup meet this month. Some of her props and examples are amazing. Girl definitely knows her Model A lights!
Old 05-07-2026, 11:24 AM   #19
jeepguy1948
I bought the A style lamp (I have not been able to install them yet due to a health problem) purely because of a video by PS (Thank You Paul Shinn!!!).
jeepguy1948 is offline   Reply With Quote
Old 05-07-2026, 01:03 PM   #20
Trapdoor2
Trapdoor2's Avatar
I installed the "A" LED variation. They work fine and testing them via the original aiming spec (shown in various books), they seem fine. I have not driven after dark...yet!
'31 Ford Deluxe Coupe "The Green Hornet"
Trapdoor2 is offline   Reply With Quote
