Old 04-30-2026, 02:28 PM   #1
jdjj
Default 1935 pickup windshield install
Replacing windshield on pickup. Cant get glass to settle in track with seal that came with glass' Are there different thickness of settling tape? I put seal on glass but wont allow the 2 half's of frame to come together.
jdjj is offline   Reply With Quote
Old 04-30-2026, 02:55 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1935 pickup windshield install
There are different thicknesses of tape. To determine what is correct for your project, measure the thickness of the glass (G), then the width of the channel (C).
Subtract the thickness of the glass from the width of the channel. Divide that result in half.
C-G / 2 = tape thickness.
Measure accurately. A micrometer on the glass is good. The end of a drill bit that fit nicely in the channel works well.
The channel MUST be super clean.
Use glass cleaner (spray) when installing the glass w / tape. It's slippery and dries out and will not later suds when it gets wet.
Old 04-30-2026, 03:45 PM   #3
rich b
rich b's Avatar
Judicial use of a rubber mallet usually helps to persuade it.
rich b is offline   Reply With Quote
Old 05-01-2026, 08:54 AM   #4
37 truck
I have used long bar clamps with the rubber pads on the clamps, works good to pull them together.
37 truck is offline   Reply With Quote
Old 05-02-2026, 08:28 PM   #5
jdjj
thanks for all the info. Doing those measurements looks like i need 1/16. The one that came with it is double that,
