Old 04-26-2026, 09:37 PM   #1
Paul Bishop
Default Rain Gutters 31' Coupe
When I restored my coupe the rain gutter were quite rusted. Since I could not get them off I used bondo and sanded the smooth
Here twenty years later the rust has come back and I would like to take them completely off this time
Are there screws holding them on, or are that tack welded on.
Paul Bishop is offline   Reply With Quote
Old 04-27-2026, 04:38 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Rain Gutters 31' Coupe
Spot welded. You really need to get to the back side….or at least that’s the way I work them
Oldbluoval is offline   Reply With Quote
Old 04-28-2026, 10:24 PM   #3
Bick in New Zealand
Bick in New Zealand's Avatar
Eventually, that is a task I am going to have to tackle, as mine were missing when I restored my coupe. I used aluminium extrusions, attached with small screws, that were countersunk, then filled over with bog. After many years some of the filler is starting to pop. When I replace them it will be with something more authentic.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 04-28-2026, 11:37 PM   #4
Bick in New Zealand
Just spotted these on ebay. They look better than anything else I have seen. https://www.ebay.com/itm/23670235101...Bk9SR8rR-fe6Zw
1931 Victoria RHD
Old 04-29-2026, 03:16 AM   #5
Oldbluoval
Oldbluoval's Avatar
I’m agreed they do look good! And steel not aluminum
Priced well! Worth a risk to look see at that price.
I might buy couple of pair for stock. Parts go away really quickly these days
Whoa! Only two sets available! Jump!
Old 04-29-2026, 10:20 PM   #6
Paul Bishop
So on the 31' Coupe, should I grind the rain gutters off and start from scratch
