Old 04-22-2026, 12:12 PM   #1
jeepguy1948
Default Gas Tank Neck Extension?
I see ads for the tank extension but I can’t figure out how it makes fueling easier.
jeepguy1948 is offline   Reply With Quote
Old 04-22-2026, 12:24 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Gas Tank Neck Extension?
It provides enough of a rise to disable the nozzle from shutting off.
Tacoma Bob is offline   Reply With Quote
Old 04-22-2026, 01:28 PM   #3
jeepguy1948
Do you only install it when fueling or does the gas cap fit on it?
Old 04-22-2026, 02:04 PM   #4
The Master Cylinder
The Master Cylinder's Avatar
Only install it when refueling, there is no provision to install the cap on the extension.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 04-22-2026, 04:23 PM   #5
ModelA29
ModelA29's Avatar
It's useful here in the peoples republic of CA to hold the sealing ring of the vapor recovery nozzles back so you can get 2-3" more gas in the tank.
People in the free world with normal nozzles don't need them.
I saw a couple months ago the maker was going to retire from making more.
ModelA29 is offline   Reply With Quote
Old 04-22-2026, 04:38 PM   #6
nkaminar
nkaminar's Avatar
The vapor recovery seal can be held up with one hand while you are controlling the nozzle with the other. That way the gasoline will flow.
Old 04-22-2026, 06:03 PM   #7
ModelA29
ModelA29's Avatar
Which is in reality easier than the adapter. I get a kick out of the fact the underground fuel tanks that are collecting the fumes are still vented to the atmosphere. Usually pipes at roof level behind the station. They are as effective as CA "summer blend" gas that really only stops the emissions turning brown in the summer when the UV rays are the highest. The air is still bad but you've been scammed into paying higher prices for healthier air that really isn't.
Photochemical smog is a type of air pollution characterized by a brownish haze that forms in urban areas, primarily resulting from the reaction of sunlight with pollutants like nitrogen oxides and volatile organic compounds (VOCs). It is often referred to as "Los Angeles-type" or summer smog, commonly appearing in sunny, warm, dry climates with high traffic density.
Old 04-22-2026, 06:05 PM   #8
BButturff
BButturff's Avatar
I would think one could make a temporary extension from a short piece of PVC pipe.
_______________________
The other Bruce in Minnesota
1931 Model A Closed Cab (Budd) Pickup "Aurora"
Model A Ford Club of America
Lady Slipper A's
"You can't go back and change the beginning,
but you can start where you are and change
the ending." - C.S. Lewis
BButturff is online now   Reply With Quote
Old 04-22-2026, 07:31 PM   #9
Bruce of MN
Bruce of MN's Avatar
I use a pvc socket to male npt adapter. I'm away from home, so I don't know the size.
Bruce of MN is offline   Reply With Quote
Old 04-22-2026, 10:15 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
Probably not a good idea. The gas nozzle needs to be grounded to the car to prevent static electricity. Or maybe that why Ford installed a spark arrestor.
Ever wonder why modern cars still use metal filler necks?
Old 04-22-2026, 10:19 PM   #11
Big hammer
When you pump gas and the metal nozzle touches the tank it makes a ground path for static electricity, with a PVC adapter no path for static electricity, keep your free hand in contact with the gas tank opening and the pump nozzle . i was taught to keep the pump nozzle in contact with the tank opening refueling light planes at the local airport as a teenager . As an inquisitive kid I asked about the rubber hose and was told fuel hoses conduct electricity by wire embedded in the fuel hoses .
get a bigger hammer tap done
Old 04-23-2026, 08:13 AM   #12
JayJay
I hold up the California nanny collar with one hand, bridge the resulting spout across the tank making contact, then use the other hand to operate the handle. Much like NK notes above, but being sure to maintain a static ground path. Pretty easy to do once you’ve done it a couple of times.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 04-23-2026, 08:38 AM   #13
Y-Blockhead
Thing is, with the extension, you stick the nozzle in, start the pump and it shuts off automagically when full. Just like a Modern. That is the whole point of the extension.
Old 04-25-2026, 04:54 AM   #14
LAV
LAV's Avatar
I like the extension. Works great even in Cali. No gas spills and ez to use.
LAV is offline   Reply With Quote
Old 04-25-2026, 02:11 PM   #15
AL in NY
AL in NY's Avatar
Another benefit of the extension, you can't dent the top of the fuel tape ring which would case the cap not to seal...........thus a fuel leak when the tank is full.
AL in NY
AL in NY is offline   Reply With Quote
Old 04-25-2026, 02:31 PM   #16
ModelA29
ModelA29's Avatar
Originally Posted by Big hammer View Post
....... i was taught to keep the pump nozzle in contact with the tank opening refueling light planes at the local airport as a teenager ..
We also had a alligator clip on a wire we had to unreel and connect to the airplane to make sure it was grounded.
BTW: for the last 15+ years Ford had used plastic fill necks - and tanks.
Old 04-25-2026, 04:37 PM   #17
Y-Blockhead
Really?? Looks like metal to me...
