Old 04-21-2026, 10:47 AM   #1
Sid
Sid's Avatar
Default 1940 Ford coupe trunk hinge springs
Is it best to change the whole hinge arms and springs or just replace the coil spring? I have read a few of the horror stories how sometimes replacing the whole unit the trunk sticks up or they bind. I know the complete unit is about $150.00. How hard is it to just replace the spring? I see it has a guard. Do you drill the spot welds or just bend it out of the way then bend it back? I see C&G and CW Moss is out of stock. Who is carrying the best arm assy or the springs? Which is the best wat to go?
Sid is offline   Reply With Quote
Old 04-21-2026, 11:30 AM   #2
TJ
TJ's Avatar
Default Re: 1940 Ford coupe trunk hinge springs
Try Sacramento Vintage Ford or All Ford Parts in Campbell, Ca.
Old 04-21-2026, 11:37 AM   #3
Kube
Super Moderator
Kube's Avatar
Sid, from a LOT of experience, the springs are not typically an issue. Rather, the pivot points are worn out, resulting in the lid not being held up properly.
If you are able to replace the rivets at the center pivot AFTER you have welded the elongated holes up and redrilled them to size, then go that way.
If you are not able, buy new.
Kube is online now   Reply With Quote
Old 04-21-2026, 10:44 PM   #4
Newc
Newc's Avatar
No longer made ?? Out of stock locally. Newc
Old 04-22-2026, 05:50 PM   #5
19Fordy
19Fordy's Avatar
Sid, I fixed my sagging 1940 Ford coupe trunk springs years ago as shown in the thread.
https://www.jalopyjournal.com/forum/...hinges.152557/
