Old 04-15-2026, 11:25 PM   #1
sandbug
Default '39-41 Ford Brakes - Clip Identification
Took these out super easily before disassembly of everything for fixing, cleanup and re-painting. Can't seem to find a picture beforehand, so can anyone identify where these go?
A picture or diagram would be helpful. Thx!
sandbug is offline   Reply With Quote
Old 04-15-2026, 11:28 PM   #2
sandbug
Default Re: '39-41 Ford Brakes - Clip Identification
Here is the earliest photo.
Old 04-15-2026, 11:39 PM   #3
petehoovie
petehoovie's Avatar
Attachment 584451
Old 04-15-2026, 11:40 PM   #4
petehoovie
petehoovie's Avatar
Attachment 584452
Old 04-16-2026, 12:43 AM   #5
hueyhoolihan
i've recently had both rear hubs (1941 super deluxe) and brakes disassembled, down to the last horseshoe retainer, backing plate and pivot bolt and don't remember seeing anything like those. they may have been used to retain the sheathed e-brake cable to the frame as it winds its way from the handle to underneath the car where it attaches to the rear cable. or possibly the flexible rubber brake lines that run to the brake cylinders. *headscratch*
if they involved the front brakes, i'm of no help, as i haven't had cause to go there...yet.
hueyhoolihan is offline   Reply With Quote
Old 04-16-2026, 03:07 AM   #6
Randy in ca
Randy in ca's Avatar
Attachment 584451
Those are the brake shoe retaining clips for 1942-48 front backing plates (which the second picture of everything appears to show that you are working with). The just slip into place on the backing plate. The 1939-41 clips were kind of mushroomed after they were put in place to retain them.
Randy in ca is offline   Reply With Quote
Old 04-16-2026, 05:55 AM   #7
glennpm
glennpm's Avatar
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 04-16-2026, 07:49 AM   #8
rich b
rich b's Avatar
Your rear brakes are '39-'41.
rich b is offline   Reply With Quote
Old 04-16-2026, 11:28 AM   #9
hueyhoolihan
yes, i do recall, very well, the two clips on each backing plate, but they were not removeable on my backing plates, AFAIK.
and BTW, notice the spring. the hook points up on one end and down on the other. and if the "up" end is not attached from underneath on the proper shoe (i.e. the front or rear shoe and unfortunately i don't remember which) the shoes cannot be fitted properly, if at all. and what's worse is that it may not be apparent until the e-brake levers are being fitted...or maybe i should say are FAILing, over and over and over again, to be fitted.
and don't forget that those e-brake levers are NOT symmetrical. there are two for the right side and two different ones, although only slightly different, for the left side. mine were stamped "LH" and "RH".
Old 04-16-2026, 01:27 PM   #10
sandbug
Thanks and thanks!
