Old 04-11-2026, 08:30 PM   #1
oldgas
Default slinger
Can you tell me how essential or important the oil slinger on the crankshaft I am understanding it keeps the oil away from the crank seal. Would I be correct in saying that? The slinger was missed on a re-build.
Thank you in advance for your input.
Oldgas.
oldgas is offline   Reply With Quote
Old 04-13-2026, 02:51 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: slinger
Which engine are you working on? Yes an oil slinger keeps oil away from the seal so it can drain back into the pan.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-15-2026, 07:11 AM   #3
oldgas
Default Re: slinger
I'm working on a y-block 292
Old 04-15-2026, 10:20 AM   #4
1930artdeco
Default Re: slinger
I have the same engine and cannot remember about the oil slinger. Tim McMaster rebuilt my engine and he is at:
http://yblockguy.com/
There is also Mummert ([url]http://www.ford-y-block.com) in SoCal. and Ted Eaton (www.eatonbalancing.com). These are the big three when it comes to Y blocks. All of them are very helpful if you call them.
Mike
1957 Country Sedan
Old 04-16-2026, 08:49 PM   #5
oldgas
Default Re: slinger
Thank you for the contact information & your time.
Cheers Oldgas
