#1 |
With these Accessory 1955-1956 Ford Wire Wheel Covers, how many Clips do they require? Is it 4 or 5? |
#2 |
This is what the Accessory Wire Wheel Cover Retaining Clip looks like. How many are required for each wheel - 4 or 5 ? |
#3 |
#4 |
Thank you Mike - very enlightening. Regards Mercman <><
#5 |
Installation Instructions, Compliments CASCO Thunderbird Specialists |
#6 |
I just got three spare used wire style wheel covers and they came with a bag full of spring clips. I might install a few clips next time the tires are replaced. Last edited by dmsfrr; 04-11-2026 at 05:02 AM. |
#7 |
1955 Ford Thunderbird with Accessory Wire Wheel Covers - dmsfrr |
#8 |
Australian 1956 Ford Customline with Accessory Wire Wheel Covers. Apart from a Mainline Utility, this was the only 56 Ford V8 offered in Australia. We never received any other body styles or the upmarket Fairlane models. They all were powered by the 272 Y Block with Three Speed Manual Transmission. This photo was taken over 40 years ago, and I haven't seen this car since. The owner didn't like the inconvenience of pulling out these Wheel Covers to check the Tyre Pressure. His solution was to drill a hole to allow the Valve Stems to protrude - problem solved! However, after his first drive, he noticed that no valve Stem was protruding. Result - Set of NOS Accessory Wire Wheel Covers destroyed. |
#9 |
1956 Ford Crown Victoria Skyliner with Accessory Wire Wheel Covers |
