Old 03-30-2026, 01:51 PM   #1
HBoly44
Default stgarter removal on 1955 272wha
how do you remove starter from a 272 automatic. got it loose but can not get it out of the engine. how do you get it out ?
HBoly44 is offline   Reply With Quote
Old 03-30-2026, 05:01 PM   #2
Throck Morton
Default Re: stgarter removal on 1955 272wha
If the starter is indeed loose with all three mounting bolts removed, then it is probably hung up on the bendix drive.
The bendix is quite large and mounted AFTER the much smaller pinion drive gear. It will hang up on the flexplate. You have to tilt the starter around to remove it. Ford called it the 'Folo-Thru'.
Throck Morton is offline   Reply With Quote
Old 03-30-2026, 05:14 PM   #3
40 Deluxe
As I remember, it is easier to remove if you have just run the engine and shut it off without trying to restart it. This will leave the Bendix (drive gear) retracted thus easier to remove. If you have cranked the engine over without starting, the Bendix gear has extended into the flywheel teeth making it harder to remove.
