Old 03-28-2026, 02:04 PM   #1
Bustingear
Default Need some help on ID for these Model T aprons
Need some help on ID for these Model T aprons, Thanks
Bustingear is offline   Reply With Quote
Old 03-29-2026, 10:10 AM   #2
gz
gz's Avatar
Default Re: Need some help on ID for these Model T aprons
Looks like 1917-1925 touring/roadster splash aprons. Desirable and better than the reproductions.
gz is offline   Reply With Quote
Old 03-29-2026, 10:11 AM   #3
Russ Furstnow
These splash shields fit a 1915-1916 Ford. There is no hole in the apron for the speedometer cable. I hope this helps, Russ Furstnow
Russ Furstnow is offline   Reply With Quote
Old 03-29-2026, 11:12 AM   #4
rotorwrench
rotorwrench's Avatar
I seem to remember that those last brass cars only had one short cut out on the top inside edge. The ones above have the long one and the shorter cut out in the top edge.
Speedometers were more of an option in the early years. The other thing I'd like to mention is that there were a lot of reproduction parts made over the many years since production ceased. I've seen reproduction parts with the same patina as those. They may very well be original but there has been a lot of water under the bridge in 100+ years since.
Old 04-07-2026, 06:13 PM   #5
tmiller6
tmiller6's Avatar
My vote is 17-25 based on the two holes at the back. There is a wide hem on the back side to tie into the crowned fender.
tmiller6 is offline   Reply With Quote
