Old 03-27-2026, 05:47 PM   #1
392 Hemi
Default 1932 Ford rear crossmember rivets
Hi. I'm wondering what size rivets were used on the 32 Ford rear crossmember and who sells them. Any help on this is appreciated.
Thanks!
392 Hemi is offline   Reply With Quote
Old 03-27-2026, 07:17 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 1932 Ford rear crossmember rivets
Delete
Alan
Old 03-27-2026, 07:21 PM   #3
ford38v8
ford38v8's Avatar
Delete
Alan
Old 03-27-2026, 08:57 PM   #4
tubman
tubman's Avatar
Precision Coachworks in Billerica, MA used to be the "go to" for this sort of thing. Unfortunately, they have been out of business for quite a while. I have heard the Joe's Auto Parts has taken over part of that business. You may want to check with them.
You could also use Allen socket head capscrews as I suggested in the other thread.
Old 03-27-2026, 09:19 PM   #5
deuce_roadster
deuce_roadster's Avatar
Big Flats Rivets in New York.
Google them.
Old 03-27-2026, 10:46 PM   #6
petehoovie
petehoovie's Avatar
Google them.
Big Flats Rivet Co
Address: PO Box 100
Big Flats, NY 14814-0100
USA Phone Number (607) 562-3501
Old 03-27-2026, 10:59 PM   #7
petehoovie
petehoovie's Avatar
https://rapidrivet.com/industrial-ri...r-applications
Rapid Rivet & Fastener Corp.
Call Toll Free : 800 - ( 727 - 4378 )
Minimum Order Requirements:
Rapid Rivet has a $35.00 minimum order requirement per purchase order for domestic (U.S.A.) shipments, and an $10.00 individual line minimum.
Rapid Rivet delivers industrial rivets and fasteners for a wide range of sectors:
www.jalopyjournal.net-Aerospace: NAS and MS spec rivets for aircraft skin, interior, and structural assemblies
-Defense: High-performance fasteners for vehicles, weapon systems, and electronics
-Automotive: Body panels, structural frames, and trim with corrosion-resistant fasteners
-Electronics: Miniature rivets for enclosures, terminals, and PCBs
-HVAC & Rail: Vibration-resistant rivets for ducts, railcars, and infrastructure
-Marine & Infrastructure: Corrosion-resistant solutions for shipbuilding and bridge components
Our inventory depth and fast shipping make us the preferred partner for time-sensitive and large-scale projects.
Old 03-28-2026, 01:45 AM   #8
BlueNotes
Michael at ThirdGenAutomotive has the 5/16" rivets required for the rear crossmember.
https://thirdgenauto.com/product/5-1...en-1-1-4-long/
BlueNotes is offline   Reply With Quote
Old 03-28-2026, 10:24 AM   #9
rotorwrench
rotorwrench's Avatar
Heat them up red hot and drive them with a proper rivet set and 5X gun or larger. You can use a hammer but it takes longer and the hammer work has to be precise. It takes two people to do this type of work. The largest bucking bar you can find or make is advised.
Old 03-28-2026, 12:39 PM   #10
392 Hemi
Thank you guys so much for your help with this. Any advice on making the rivet set and bucking bars?
Old 03-28-2026, 06:09 PM   #11
rotorwrench
Sets are available from model A sources. A big chunck of steel is the best bucking bar. Maybe a big hammer head.
Old 03-28-2026, 08:05 PM   #12
392 Hemi
Thank You!
