Old 03-24-2026, 02:08 PM   #1
jdpaxton
Default `42-48 crabby distrib
Repairing a crab cap distrib and the first thing I spotted under the cap was the broken copper connector between the 2 points and the brass post for the hot wire. This is made from .010 copper sheet. Not impossible to find but to replace the rivets etc and insulation seems excessive. Anyone have an easier cure?
jdpaxton is offline   Reply With Quote
Old 03-24-2026, 03:41 PM   #2
glennpm
glennpm's Avatar
Default Re: `42-48 crabby distrib
The copper strips are part of the points assembly.
The brass post can be repaired. I had a very short stub left on one of mine. I used a coupler and a brass stud to fix it.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 03-24-2026, 05:28 PM   #3
jdpaxton
Thanks Glen. Actually my points are like shown but a separate copper strip, is sandwiched on the brass post with 2 tails, one to each point set. The brass post I am referring to, is the one attached with rivets to the contact mounting plate. The pic you sent is a great repair to the hot lead post. The hot lead post screws into the distrib and has a spring loaded contact that feeds power to the brass post which contains the copper strip.
Old 03-25-2026, 06:14 AM   #4
glennpm
glennpm's Avatar
Yes I get it now.
Rumble Seat’s Notes
