Old 03-21-2026, 01:30 PM   #1
Daveyyc
Default Fuel pump Push Rod
I have changed the intake manifold on a 59 series V8 for the original style intake which has a lower generator and fuel pump mount. The fuel pump push rod is now too long and needs to be shortened by 1 inch. Can I cut the 1 inch off of the top of the existing rod rather than acquiring the shorter version.
Daveyyc is offline   Reply With Quote
Old 03-21-2026, 02:00 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Fuel pump Push Rod
The tips of the push rod might be hardened, especially the end that rides on the cam.
Get the correct rod , if possible.
Here's an idea: Make an adjustable push rod.
Old 03-21-2026, 02:06 PM   #3
Kube
Super Moderator
Kube's Avatar
100% correct in the hardened tip advice. The early engines used the rod that was 1" shorter than the later rods. They are readily available from Carpenter, etc.
Old 03-21-2026, 10:23 PM   #4
Daveyyc
Thank you for the advice. I will go find a shorter pushrod
