Old 03-14-2026, 12:14 PM   #1
Stephenorf
Stephenorf's Avatar
Default 1959 MEL door glass verticle anti rattle
This goes in the door in the rear window channel. Mine are all worn out, and the driver's side is broken. Does any one know if other year/make/model inserts would fit my 1959 Mercury Monterey? If not, I'll have to fabricate/refurbish/reuse the ones I have.
Stephenorf is offline   Reply With Quote
Old 03-14-2026, 05:09 PM   #2
miker98038
miker98038's Avatar
Default Re: 1959 MEL door glass verticle anti rattle
Try https://www.restorationspecialties.com/. They’ve got a pretty good selection of that sort of window pieces. Good quality stuff in my experience.
miker98038 is offline   Reply With Quote
Old 03-14-2026, 08:02 PM   #3
evintho
evintho's Avatar
This is what you need.......
https://www.rubbertherightway.com/19...85482-prd1.htm
evintho is offline   Reply With Quote
Old 03-14-2026, 09:21 PM   #4
Stephenorf
Stephenorf's Avatar
Thanks for the link. It looks like they might have some things I need.
Old 03-14-2026, 09:21 PM   #5
Stephenorf
Stephenorf's Avatar
Originally Posted by evintho View Post
I'll take measurements tomorrow, but that looks like the right stuff. Thanks for the lead.
Old 03-16-2026, 04:27 PM   #6
Gene F
Gene F's Avatar
You can buy a similar strip, and glue it on from Snyders Antique Auto Parts, New Springfield, Ohio. Model-A uses about the same thing. No metal edge on it though. The lengths are cut to fit, but I doubt you ever would.
I just clean the surface, apply the glue, and slip them in place. The roll the window up for a few days with some posterboard from the dime store between the window and the strip.
The one that goes on the vent-a-payne is a whole other kettle of fish.
Gene F is offline   Reply With Quote
Old 03-16-2026, 04:29 PM   #7
Gene F
Gene F's Avatar
BTW, JC Whitney used to sell the ones you have now. I have no idea if they, or Warshowski are still in business.
Old 03-18-2026, 03:07 PM   #8
1930artdeco
1930artdeco's Avatar
You can always use the soft fuzzy side of velco to glue/staple into place and you will be set.
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-20-2026, 05:43 PM   #9
Stephenorf
Stephenorf's Avatar
Thanks to all. I think I'll start with the Velcro suggestion. Seems that since the fuzzy part is what is worn out, so I should be able to just re-apply and no more rattle. We'll see how it goes.
Old 03-21-2026, 06:58 AM   #10
Ford blue blood
Ford blue blood's Avatar
I have used the Velcro thing for years. Tedious but worth the effort! I started doing it before all the re-poped stuff was out there. Now I just go with it when doing a resto.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
