Old 03-07-2026, 06:27 PM   #1
kurt v
Default fuel pump push rod 59 ab
what should the push lift be, i have about 5/16" is that enough ?
thanks kurt
kurt v is offline   Reply With Quote
Old 03-08-2026, 05:39 AM   #2
SHORTDOOR
SHORTDOOR's Avatar
Default Re: fuel pump push rod 59 ab
I believe I measured about a 1/4 inch on mine. Sand the base of the stand flat and use the thin gasket under it. Also make sure your push rod ends are not worn.
SHORTDOOR is offline   Reply With Quote
Old 03-08-2026, 11:58 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
thanks kurt
That seems about right . . . as long as you have the correct push-rod, you should be good to go.
Old 03-08-2026, 12:36 PM   #4
Bruce_MO
I recall the lift is supposed to be 0.20”… a bit less than 1/4”.
Bruce_MO is offline   Reply With Quote
