Old 03-03-2026, 12:35 AM   #1
1EarlyA
Default Difference between car and pickup crossmember?
I have a 1936 Ford car chassis that I will actually be putting under a pickup. Years ago I thought I read that the front crossmember on a car frame and the crossmember on a pickup frame were different (I believe it said one dips down lower than the other).
Can someone verify or refute this for me?
Thanks
1EarlyA is offline   Reply With Quote
Old 03-03-2026, 03:09 AM   #2
Mart
Mart's Avatar
Default Re: Difference between car and pickup crossmember?
Pretty sure the 1936 car and pickup front crossmembers are the same. There is a difference in the body mounts that are on the side of the frame, as in none on a pickup but the basic frame is the same.
You might be thinking of a 41 pickup frame where there is a deeper front crossmember to accommodate the six cylinder engine.
Old 03-03-2026, 05:39 AM   #3
deuce lover
deuce lover's Avatar
In 1937 it dipped down.
deuce lover is offline   Reply With Quote
Old 03-03-2026, 08:42 AM   #4
TomT/Williamsburg
TomT/Williamsburg's Avatar
I think it dipped down when a 4-cyl was installed?
Anyway I have a 36 car chassis under my 40-41 pickup and had no front crossmember issues. However one thing to know is that the tail end of your chassis narrows vs later chassis's. Most everything else is there where you need it to be.
Good luck!
TomT/Williamsburg is offline   Reply With Quote
Old 03-03-2026, 09:13 AM   #5
Model51
Model51's Avatar
The 1936 Ford Chassis book lists 48-5020 as the front crossmember for both Model 68 (car) and Model 67 (pickup). So car and pickup use the same front cross member in 1936.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 03-03-2026, 12:09 PM   #6
petehoovie
petehoovie's Avatar
Good luck!
Old 03-03-2026, 08:00 PM   #7
1EarlyA
What a coincidence. That is the specific intent for this chassis.
Old 03-03-2026, 08:02 PM   #8
1EarlyA
FYI The reason I asked about the height of the crossmember was because I am hoping there is a way to raise the front end a few inches without putting a tube straight axle under it.
Don't get me wrong, I absolutely LOVE a vehicle with a straight axle, but I am trying to keep this project as reasonably priced as I can.
If money were no object I would love something like this.
