Old 02-27-2026, 11:27 AM   #1
Automotive Stud
Automotive Stud's Avatar
Default 1946 Gas door bumpers
Does anyone know which style 11a-16378 bumpers are correct? Drake shows them pointed but everyone else shows them as round and flat. I have mismatched ones in the car now and the gas door sticks up too far. Just want to make sure I get the right one. Thanks!
Automotive Stud is offline   Reply With Quote
Old 02-27-2026, 11:49 AM   #2
TJ
TJ's Avatar
Default Re: 1946 Gas door bumpers
Which one is making the door to stick up? Put some chalk on the tip of each one and close the lid. Lift the lid and look for the mark. Then you will know which one sticks up too far. Then buy the other style.
Old 02-27-2026, 11:54 AM   #3
Automotive Stud
I think what I have is hardware store stuff someone put in.
Old 02-27-2026, 03:17 PM   #4
Karl Wescott
Karl Wescott's Avatar
I am not sure what is correct, but a tapered style will tend to have a progressive rate of compression to force, a rounded one even and be a little more forgiving on adjustment.
TJ's chalk idea is great though I would use a small ball of soft modeling clay.
If you have oversized bumpers just sand them down. If they are too soft to sand easily (Drake's stuff often is which is usually a good thing) put them in a deep freezer overnight and sand when frozen
Karl Wescott is offline   Reply With Quote
Old 02-27-2026, 03:38 PM   #5
FortyNiner
FortyNiner's Avatar
Mine are flat.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 02-28-2026, 01:48 PM   #6
Bruce_MO
Pictures from my recently finished ‘46 Mercury. I got the bumpers from Drake. The fit is pretty good. Bumpers are slightly smaller than a pencil eraser and a little shorter.
Bruce_MO is offline   Reply With Quote
Old 02-28-2026, 01:48 PM   #7
petehoovie
petehoovie's Avatar
Old 03-03-2026, 08:06 AM   #8
Automotive Stud
Very nice thank you!
