Old 02-25-2026, 12:34 PM   #1
deuce lover
deuce lover's Avatar
Default Spring perch ID
Can anyone ID these spring perches? Thank
deuce lover is offline   Reply With Quote
Old 02-25-2026, 12:34 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Spring perch ID
Old 02-25-2026, 12:41 PM   #3
deuce lover
Thanks Pete.Please enlarge the second pic I just posted.
Old 02-25-2026, 01:05 PM   #4
petehoovie
petehoovie's Avatar
Old 02-25-2026, 01:35 PM   #5
rich b
rich b's Avatar
Look like '40 & '41 Ford and probably more.
rich b is offline   Reply With Quote
Old 02-25-2026, 02:34 PM   #6
alchemy
alchemy's Avatar
Yup, not actually spring perches. They fit in the same spot, but the pin is to attach the sway bar link, not a spring shackle.
alchemy is offline   Reply With Quote
Old 02-25-2026, 03:17 PM   #7
Kube
Super Moderator
Kube's Avatar
1940 passenger cars that were equipped with the second and final design of the sway bar. 1941 passenger cars that were equipped with a sway bar.
Old 02-25-2026, 07:14 PM   #8
19Fordy
19Fordy's Avatar
Some 1940 -41 info.
Old 02-25-2026, 07:18 PM   #9
petehoovie
petehoovie's Avatar
Originally Posted by 19Fordy View Post
Some 1940 -41 info.
Old 02-26-2026, 01:14 AM   #10
deuce lover
Thanks guys.Not much into 40's and All my books are packed for moving across the pond.
Old 02-26-2026, 09:17 AM   #11
Kube
Super Moderator
Kube's Avatar
This photo may add a little bit of clarity...
RADIUS ROD BOLTS
Commonly referred to as “perch bolts” there were three different designs utilized.
A pair (left in photo) of bolts (78-3032) was used on V8 models that were not equipped with a ride stabilizer. One right (01A-3032-A) and one left (01A-3033-A) were utilized with the first design ride stabilizer assembly (center of photo). Each had a grease fitting. These had a 5/8” diameter bushing hole. Released for immediate use on January 14, 1940, redesigned and renumbered right (01A-3032-B) and left (01A-3033-B) had a ¾” diameter bushing hole.
Lastly, renumbered right (01A-3032-C) and left (01A-3033-C) and redesigned (right of photo) to accept the later and final design of ride stabilizer assembly, these bolts were released for immediate use in mid December, 1939..
A special slotted nut (B-3036) and plain steel cotter pin (72035-S) held each bolt in place
Old 02-26-2026, 10:01 AM   #12
19Fordy
19Fordy's Avatar
Thanks "Kube" for posting all that info. about perch bolt changes. I never knew that. Thought all were the same size.
