Old 02-24-2026, 05:09 PM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default oil
I was curious, has anyone used or have an opinion on Lucas Hot Rod oil with zinc in a flathead motor? Thanks
bobsmanstuff is offline   Reply With Quote
Old 02-24-2026, 05:45 PM   #2
The Art Doctor
The Art Doctor's Avatar
Default Re: oil
Give this a watch and see about oils marketed for vintage cars:
https://www.youtube.com/watch?v=a3uXSI9wQv8
The Art Doctor is offline   Reply With Quote
Old 02-24-2026, 06:46 PM   #3
KiWinUS
KiWinUS's Avatar
Default Re: oil
Save us all some pain and do a little research on your own. It’s too easy. This has been covered numerous times.
Old 02-24-2026, 07:01 PM   #4
bobsmanstuff
Default Re: oil
Excuse me for asking.
Old 02-24-2026, 07:07 PM   #5
petehoovie
petehoovie's Avatar
Default Re: oil
GOOD STUFF! IT WORKS!
Old 02-24-2026, 07:15 PM   #6
leon bee
Default Re: oil
My only opinion is that easy to get NAPA oil sure seems to work well in everything.
leon bee is offline   Reply With Quote
Old 02-24-2026, 08:13 PM   #7
Gene1949
Gene1949's Avatar
Default Re: oil
I've been using Castrol GTX 20-50 for 25 years. Stock cam and Johnson lifters.
I don't think a stock flatty has enough valve spring pressure to warrant the expense of the Rodney Racer oils.
Gene1949 is offline   Reply With Quote
Old 02-25-2026, 09:40 AM   #8
35fordtn
35fordtn's Avatar
Default Re: oil
Any modern oil is better than what these engines had originally. If you think you need "Zinc" Kendall GT-1 is the way I go.
35fordtn is offline   Reply With Quote
Old 02-27-2026, 11:13 AM   #9
Kube
Super Moderator
Kube's Avatar
Default Re: oil
Yes sir, the key phrase being "if you think you need".
You don't, not a stock flathead.
Old 02-27-2026, 12:34 PM   #10
tubman
tubman's Avatar
Default Re: oil
Except for non-detergent. I hate to be a broken record, but there are still some out there that think it is OK because it was what was available "back in the day".
Old 02-27-2026, 12:59 PM   #11
Anteek29
Anteek29's Avatar
Default Re: oil
Discussions of oils always creates controversy. Keep in mind - today's oils are so much better than what was available years ago.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 02-27-2026, 02:38 PM   #12
Kube
Super Moderator
Kube's Avatar
Default Re: oil
Very good point!
Old 02-28-2026, 07:15 AM   #13
fredM
fredM's Avatar
Default Re: oil
For me, it's 10-30 non detergent, and I add Zinc.
fredM is offline   Reply With Quote
Old 03-02-2026, 04:24 PM   #14
40 Deluxe
Default Re: oil
Where can you find 10-30 non-detergent oil?!
Old 03-02-2026, 07:38 PM   #15
fortyfords
fortyfords's Avatar
Default Re: oil
Why do you want to screw around looking for some special oil, like Gene1949 says, go to Walmart and buy 20-50 GTX as I do the same as he does and I have never had any problems either. You can go to any auto parts store and get the same oil as GTX. Keep it simple.
fortyfords is offline   Reply With Quote
Old 03-02-2026, 09:55 PM   #16
tubman
tubman's Avatar
Default Re: oil
But... You can always use any leftover non-detergent in you air compressor.
Old 03-03-2026, 04:08 AM   #17
fredM
fredM's Avatar
Default Re: oil
Autozone, Oreilly's, NAPA. etc. Non detergent oil is easy to find.
Old 03-03-2026, 12:51 PM   #18
tubman
tubman's Avatar
Default Re: oil
Perhaps it shouldn't be.
Old 03-03-2026, 01:51 PM   #19
leon bee
Default Re: oil
I bought some once for a break in, seemed to work pretty well, didn't leave it too long.
Old 03-04-2026, 07:41 AM   #20
joe 1950
joe 1950's Avatar
Default Re: oil
you put detergent in your washer when you clean your dirty shop clothes. ? ?
joe 1950 is offline   Reply With Quote
