I was curious, has anyone used or have an opinion on Lucas Hot Rod oil with zinc in a flathead motor? Thanks
Give this a watch and see about oils marketed for vintage cars:
https://www.youtube.com/watch?v=a3uXSI9wQv8 |
Excuse me for asking.
#5 | |
GOOD STUFF! IT WORKS! |
I've been using Castrol GTX 20-50 for 25 years. Stock cam and Johnson lifters.
I don't think a stock flatty has enough valve spring pressure to warrant the expense of the Rodney Racer oils. |
Any modern oil is better than what these engines had originally. If you think you need "Zinc" Kendall GT-1 is the way I go.
#9 | |
Super Moderator
You don't, not a stock flathead.
Except for non-detergent. I hate to be a broken record, but there are still some out there that think it is OK because it was what was available "back in the day".
Discussions of oils always creates controversy. Keep in mind - today's oils are so much better than what was available years ago.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
Super Moderator
Very good point!
#13 |
For me, it's 10-30 non detergent, and I add Zinc.
#14 |
#15 |
Why do you want to screw around looking for some special oil, like Gene1949 says, go to Walmart and buy 20-50 GTX as I do the same as he does and I have never had any problems either. You can go to any auto parts store and get the same oil as GTX. Keep it simple.
#16 |
But... You can always use any leftover non-detergent in you air compressor.
#17 |
Autozone, Oreilly's, NAPA. etc. Non detergent oil is easy to find.
#18 |
Perhaps it shouldn't be.
#19 |
I bought some once for a break in, seemed to work pretty well, didn't leave it too long.
#20 |
you put detergent in your washer when you clean your dirty shop clothes. ? ?
