Old 01-29-2026, 08:24 PM   #1
Ohc Joe
Default 37 thermostat question
Ok guys on this 36 I have it has a 37 engine what thermostats do I buy im in so cal and my daughter is going to be driving this around town and high school
Thanks in advance
Ohc Joe is offline   Reply With Quote
Old 01-30-2026, 12:18 AM   #2
petehoovie
petehoovie's Avatar
Default Re: 37 thermostat question
Thanks in advance
Old 01-30-2026, 01:46 AM   #3
deuce lover
deuce lover's Avatar
Here
https://www.ebay.com/itm/255682191425
deuce lover is offline   Reply With Quote
Old 01-30-2026, 01:47 AM   #4
GB SISSON
GB SISSON's Avatar
I have been running stats from a subaru justy. 180 degree. They are available in regular auto parts stores and seem to stay put in the hose right against the necks on the heads. Hopefully someone has a part # or what year subaru is the one for our V8s.
Old 01-30-2026, 01:59 AM   #5
petehoovie
petehoovie's Avatar
Originally Posted by deuce lover View Post
Old 01-30-2026, 11:25 AM   #6
Fritz
Fritz's Avatar
I do the same as GB. Carquest 13848 Is the part number. Drill a 3/16” or so hole to avoid air pockets. And so it stays put on top of the head, I have another hose clamp right above it to squeeze the hose just enough to prevent it from moving up the hose.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 01-30-2026, 04:15 PM   #7
Ohc Joe
Awesome thanks a bunch guys will go to auto parts store and do some searching with the kid behind the counter that needs to know what year car do i have to buy windshield wiper fluid
Old 01-30-2026, 08:12 PM   #8
v8fordman
v8fordman's Avatar
Isn’t that the truth! You should have seen the kid when I went to O’Reilly’s and asked for a set of spark plugs for my ‘37 Ford pickup with a ‘55 DeSoto hemi in it. You know they have to know the make and engine size. LOL
v8fordman is offline   Reply With Quote
Old 01-31-2026, 07:57 AM   #9
Ohc Joe
Haaaaaa yep same here ok youngster im wking on a 36 ford and im using a hot rod fuse panel and need some fuses .......whatttttttttt.hahahaha.
Old 01-31-2026, 08:25 AM   #10
chap52
chap52's Avatar
Share the hobby with the youth...It and us are becoming a Flintstone adventure to the electronic generation.
I was blessed that my now custom car building son was hanging out in the shop when I was tinkering. He learned what bailing wire was for and when you needed to tap a starter with a hammer.
I read somewhere that; "let him who has received the gift freely share it." Chap
chap52 is offline   Reply With Quote
Old 02-09-2026, 11:37 AM   #11
KenBolton
When I put mine in I went with the 180 degrees option vs the 160 thinking in Wisconsin I might use the heater. While I have on occasion it is rare. As warm as these engines run I now think the cooler stat would have been the wiser choice. I always obcess with summer running temps and vapor lock.
KenBolton is offline   Reply With Quote
Old 02-09-2026, 08:01 PM   #12
JayChicago
JayChicago's Avatar
Ken
Your thermostat only helps with quick warm-up and determines the minimum operating temp. When the engine starts to run warm, both 160 and 180 stats will be wide open just the same. IMHO, 180 is better for a clean running engine.
JayChicago is offline   Reply With Quote
