Old 01-22-2026, 04:50 PM   #1
corvette8n
corvette8n's Avatar
Default This might slow my oil burning
I didn’t know this existed. 60wt. Oil with high zinc.
Old 01-22-2026, 05:12 PM   #2
leon bee
Default Re: This might slow my oil burning
^^^ Old Harley Davidson guys often have some of that around.
leon bee is offline   Reply With Quote
Old 01-22-2026, 06:20 PM   #3
34fordy
34fordy's Avatar
Talking Re: This might slow my oil burning
I am waiting for the oil that doesn't drip!
34fordy is offline   Reply With Quote
Old 01-22-2026, 06:41 PM   #4
19Fordy
19Fordy's Avatar
How does 60W affect bearings?
Old 01-22-2026, 07:22 PM   #5
JayChicago
JayChicago's Avatar
My thought too. That is not a multi-weight oil, so it will be the full 60 weight when cold. Before the engine warms and thins the oil, will 60-weight be able to get to everywhere its needed? I don't know. Maybe no problem. But maybe a dry bearing somewhere.
JayChicago is offline   Reply With Quote
Old 01-22-2026, 07:26 PM   #6
oldbugger
oldbugger's Avatar
Depends why your burning oil
oldbugger is offline   Reply With Quote
Old 01-22-2026, 10:24 PM   #7
farmertom
farmertom's Avatar
Yep,used the 60wt in my shovel head. Tom.
farmertom is offline   Reply With Quote
Old 01-23-2026, 02:05 AM   #8
J Franklin
J Franklin's Avatar
Time to fix the problem!
Old 01-23-2026, 08:32 AM   #9
corvette8n
corvette8n's Avatar
Worn rings I believe, 60 lbs compression on each cylinder, getting 40 miles of driving to the quart. I hope to swap in a Flathead motor I picked up a few years back this spring.
Old 01-23-2026, 09:46 AM   #10
hueyhoolihan
ya, 40 miles eh? sounds like a good idea. ...people behind must be wondering if they're following the Queen Mary. ha
hueyhoolihan is offline   Reply With Quote
Old 01-23-2026, 11:18 AM   #11
GB SISSON
GB SISSON's Avatar
Back in the early 70s I had a friend who drove an old rambler wagon. She would pull into the gas station and tell the attendant, "Fill it with oil and check the gas"... Personally. I have run a few loose engines on straight 40w with a couple cans of STP to quiet things down.
Old 01-23-2026, 01:16 PM   #12
ford38v8
ford38v8's Avatar
I never did open up my 59L in my ‘38 to see how it was built. It had compression in the 60’s, never dripped oil, l used Mobil 1 10-50, never had to add oil, changed oil & filter every 500 miles. 3.78 diff, top speed on the Becada desert was 78 before an occasional missed beat. I wish I hadn’t sold it.
Alan
Old 01-23-2026, 01:24 PM   #13
34fordy
34fordy's Avatar
I didn't realize there was a non dripper with that much wear. Geeesh
Old 01-23-2026, 02:44 PM   #14
glennpm
glennpm's Avatar
Sawdust works well too :-(
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 01-23-2026, 02:48 PM   #15
ford38v8
ford38v8's Avatar
I don't think it was wear. it didn't burn oil, and a 59L is a low compression engine anyway.
Ya know, I think i ought to qualify that low compression further: I was ignorant of the need to warm up an engine before taking a compression reading, so it might have had better compression than I thought at the time.
Alan
Old 01-23-2026, 04:02 PM   #16
Ronnieroadster
Ronnieroadster's Avatar
Also typically used when burning Nitro methane fuel. The amount of fuel flowing into the cylinders is so massive the engine oil gets contaminated. Heavy weight oil such as 60 wt is needed so the engine bearing's survive a 1/4 mile run.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 01-23-2026, 04:21 PM   #17
glennpm
glennpm's Avatar
Ronnieroadster
Hadn’t thought of that. Would a dry sump work?
Old 01-23-2026, 04:40 PM   #18
The Art Doctor
The Art Doctor's Avatar
Racing oil is engineered for a very short drop time not continued use. It is supposed to be run at the track one time and changed, not driven around for weeks and months. It does not have the proper additives to combat contamination and for long term stability. It has very low levels of detergents and dispersants and is designed to be used at high heat levels for short intervals. Now if you are racing your flatty, I stand corrected.
The Art Doctor is offline   Reply With Quote
Old 01-23-2026, 04:55 PM   #19
ursus
My Dad worked in sales for Texaco starting in the 1940's. For a time, his company car was a Plymouth with the flathead six. That thing was a lemon from day one and it burned oil to the tune of a quart every 100 miles. A company warehouse guy suggested the use of SAE 60 weight oil that was referred to as Aircraft-60. That stopped the smoking and extended the range to one quart per 500 miles but it was hard to start on a cold day.
ursus is offline   Reply With Quote
Old 01-23-2026, 06:34 PM   #20
1942deluxe
1942deluxe's Avatar
Maybe the same idea with GM's recall on their 6.2 engines. The fix was going from 0-20w oil to 0-40w. The feds are taking a second look at that fix.
