Old 01-18-2026, 05:00 PM   #1
Henry Ford IV
Default Need Help Installing Throttle Linkage 1935 Ford
Should this be so hard? It seems like I am fighting that spring so much. Trying to install the throttle linkage on the firewall. Two bolts! That spring seems to be so tight. Any tips?
Henry Ford IV is offline   Reply With Quote
Old 01-18-2026, 05:34 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Need Help Installing Throttle Linkage 1935 Ford
Slip the spring off of its loaded position. Install the assembly. Slip a loop of string over the curved end of the spring. Pull it back and slip the spring (end) over the throttle assembly.
Works every time and quite easy at that.
Old 01-18-2026, 06:44 PM   #3
Henry Ford IV
That's what I'm talkin about! I couldn't wait. Went to the garage and used wire, it worked like a charm! Thanks so much, I struggled with this for a few hours.
Old 01-18-2026, 07:07 PM   #4
Kube
Super Moderator
Kube's Avatar
I don't know how many I had struggled with until I took a step back, looked at it and "found" that method.
Old 01-21-2026, 04:04 AM   #5
Mart
Mart's Avatar
That's what I do. It is also useful to slip the spring arm off when taking an engine in or out. The arm flips up against the firewall instead of getting in the way. I use one of my pick tools which has a hooked end to flip the spring arm on and off.
Mart.
Mart is online now   Reply With Quote
