#1 |
Can anyone send me a plumbing diagram for a model A hydraulic brake conversion. I am trying to figure out how to plumb my single master cylinder with a 10 lb rpv from the outlet of the master cylinder to the connection of the front and rear brake lines and a low pressure brake light switch. From what I have researched the switch needs to be plumbed before the rpv so it will work correctly. Anyone have a picture or diagram of this plumbing would be greatly appreciated.
#2 | |
Plumb the switch first out of the master cylinder, then the rpv, BUT I would strongly suggest installing a mechanical brake light switch on the pedal bracket (assuming chassis mounted pedals) vs the crappy hydraulic switches now available. A quality weather resistant mechanical, like the Ron Francis SW42 I use on several cars, can handle high current halogen bulbs and allows sensitivity adjustment a pressure switch cannot. Last edited by V8 Bob; 12-16-2025 at 09:13 AM. |
#3 |
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
