Old 12-08-2025, 03:34 PM   #1
Jwawhite
Jwawhite's Avatar
Default Front E Brake Cable Rubber Tube on it.
There is a rubber tube on the sheath of the Front Emergency Brake Cable about 4" long?
Where is this supposed to 'Ride' against? Would it be between the exterior firewall at the, near the entrance site to the interior Emergency Brake Handle end?
My cable frayed at the interior wheel... froze up from lack of grease? Check yours....
Jwawhite is offline   Reply With Quote
Old 12-08-2025, 04:17 PM   #2
jplutz
jplutz's Avatar
Default Re: Front E Brake Cable Rubber Tube on it.
I had to replace the broken/frozen cables on my 52 sedan. I placed the rubber in the floor hole and use it as a seal. I think the cables in the 56 are similar. I didn't see any other rub spot. JP Lutz
jplutz is offline   Reply With Quote
Old 12-08-2025, 07:17 PM   #3
Jwawhite
Jwawhite's Avatar
JP: did the rubber come up from the undercarriage and the 'Nipple' press up against the exterior of the fire wall? What holds it from sliding down towards the ground? Or does the Nipple press up into the opening?
Thanks for responding btw
Where is Kultulz?
Old 12-08-2025, 08:43 PM   #4
51504bat
51504bat's Avatar
Where is Kultulz?
In a Galaxy far far away unfortunately.
