#1 |
It looks like the lower sector shaft has a seal that is pressed in. My question is how do I remove and replace it. Thanks
Also, on the ford barn is there a way to conduct a two or three word search, such as for sector shaft seal. If I put those three words in, the site seems to search for each individual word. |
#2 |
I use google. I would search….sector shaft seal Ford Barn….thats how I search for this site……..Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#3 |
Isn't there a qualifying phrase that you can use to limit the search to the Barn? Something like "Forum=The Ford Barn"? I seem to remember that it's a lot better than the native search.
#4 |
I'm with Mark, use google
#5 | |
Ken
https://www.nirgv8.org |
#6 |
#7 | |
Super Moderator
The only thing I do slightly different is I use self-tapping screws.
#8 |
Thanks for the suggestions.
#9 |
I must have a half dozen different slide hammers for seals. I changed a bunch of small tail rotor gearbox & turbine gearbox seals as well as sector shafts on old cars. If the lube leaks out, the the load bearing surfaces wear out too. It's best to nip it in the bud on this stuff. Some are more difficult than others so I have a lot of special tooling for the job.
