Old 10-09-2025, 03:57 PM   #1
expavr
expavr's Avatar
Default Parade Music for the Tonner.
I’m hoping one of you electrical gurus can give some advice on how to set up a sound system on the Tonner. It has a Whitney 6 Volt 40 Amp Positive Ground Alternator that I would like to use to drive a 110 Volt AC amplifier to send sound to two 50 Watt Bose speakers mounted on the truck. If using the 6 V alternator isn’t feasible any suggestions to accomplish the same result will be appreciated. Providing some patriotic music during parade events this coming year is something that I think parade watchers might appreciate. Thanks.
Les Williams
expavr is offline   Reply With Quote
Old 10-09-2025, 04:08 PM   #2
ActionYobbo
ActionYobbo's Avatar
Default Re: Parade Music for the Tonner.
Mount a 12v (si 10) alternator on the differential and mount a battery on the frame rail back there then you can run all the 12v you need.
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 10-09-2025, 04:57 PM   #3
mercman from oz
mercman from oz's Avatar
Old 10-09-2025, 05:10 PM   #4
expavr
expavr's Avatar
Thanks Yobbo. That's one helluva ingenious solution, but it involves too much surgery on the Tonner at this point. Just out of curiosity how does the driveshaft speed affect the alternator performance especially when in low gear ?
Old 10-09-2025, 06:47 PM   #5
cas3
There are 6 to 12 volt inverters, but not sure how many amps they make. Look em up on ebay
Old 10-09-2025, 07:19 PM   #6
paul2748
paul2748's Avatar
Amazon also for an inverter
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-10-2025, 07:43 AM   #7
The Art Doctor
The Art Doctor's Avatar
How about a rechargeable bluetooth speaker?
https://www.amazon.com/JBL-PartyBox-...03&sr=8-1&th=1
The Art Doctor is offline   Reply With Quote
Old 10-10-2025, 08:28 AM   #8
GB SISSON
GB SISSON's Avatar
This is the method I use. My bluetooth sound machine is called a 'tailgater' and it is plenty loud and lasts well beyond our 1/2 hour parade. No whiz-bang electrical components wired into your six volt system.
GB SISSON is online now   Reply With Quote
