Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 10-07-2025, 07:55 AM   #1
Bob Buchanan
Default Lower door seals on 37 coupe
How do you attach the lower door seals on these cars The old ones look like they used a staple. Dennis Carpenter sells the seals. Anyone else had this problem?
Bob Buchanan is offline   Reply With Quote
Old 10-07-2025, 03:00 PM   #2
Bob Buchanan
Default Re: Lower door seals on 37 coupe
Upon closer inspection I found, after removing the old seals, that they are held in place by clips that are part of the lower door. Live and learn
Old 03-12-2026, 12:57 PM   #3
normren
Attach the Dennis Carpenter lower door seals using the original-style staples or tacks into the wood strip along the door bottom. Pre-fit first, then staple every few inches. Some restorers add a small bead of silicone for extra grip, but staples are enough.
normren is offline   Reply With Quote
