Old 09-22-2025, 08:42 AM   #1
1936 ford pickup
Default wheel LUG NUT torque....
Hello,
Is there a recommended wheel LUG NUT torque for a 1935 Ford pickup.
Thank you,
Bruce in California
1936 ford pickup is offline   Reply With Quote
Old 09-22-2025, 10:08 AM   #2
T Scott
Default Re: wheel LUG NUT torque....
I don't think anyone in 1935 torqued lug nuts. Maybe at the factory. Some say torque till they squeak. I would say in answer to your question. Tight
T Scott is offline   Reply With Quote
Old 09-22-2025, 10:14 AM   #3
Mart
Mart's Avatar
I always go for about 75-80 lbft. Don't know if it is right or wrong but that's what I use. Mart.
Mart is online now   Reply With Quote
Old 09-22-2025, 10:25 AM   #4
hueyhoolihan
i generally tighten all lug nuts by hand with a lug wrench. and tighten them as tight as i can with the thought in mind that i would need to get them back off again...by hand.
hueyhoolihan is offline   Reply With Quote
Old 09-22-2025, 03:44 PM   #5
19Fordy
19Fordy's Avatar
Huey has the best technique.
As a side note, I have found lug nut washers to be very helpful.
https://www.snydersantiqueauto.com/p...6050&cat=41800
Old 09-22-2025, 04:01 PM   #6
J Franklin
J Franklin's Avatar
If I use a torque wrench I use 65# and retest after a few miles just to be safe.
Old 09-22-2025, 04:22 PM   #7
tubman
tubman's Avatar
I also use 65#, because I read it somewhere and I've never had a wheel come loose and also never had a problem loosening one.
Old 09-22-2025, 09:14 PM   #8
51woodie
51woodie's Avatar
T Scott
My grade 12 Auto Teacher once told our class if he ever caught one of us tightening wheel nuts until they squeaked, he would tighten our nuts until we squeaked. Then said to find and read the specs for the vehicle we were working on.
51woodie is offline   Reply With Quote
Old 09-22-2025, 09:29 PM   #9
3twinridges
3twinridges's Avatar
Originally Posted by 51woodie View Post
T Scott
Amen!
3twinridges is offline   Reply With Quote
Old 09-23-2025, 01:07 AM   #10
ford38v8
ford38v8's Avatar
Just as important as torqueing, perhaps even more important, is to torque in a star pattern sequence, particularly with wide five wheels, as the drum will go egg shape otherwise, raising hell with your brakes.
Alan
Old 09-23-2025, 06:41 AM   #11
glennpm
glennpm's Avatar
Yes, and I also torque to 65 lb-ft. There are many connections that I don't use3 a torque wrench for but for engine and suspension I do.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 09-23-2025, 08:45 AM   #12
Mart
Mart's Avatar
Interesting to see a value written down. 60-65 lbft. At least using 75 is on the safe side as in tighter rather than looser.
Old 09-23-2025, 09:02 AM   #13
1936 ford pickup
THANK YOU to everyone whom replied back to me and for the Torque Values chart.
I torqued mine down to 65 ft lbs in a star pattern.
THANK YOU,
Bruce in Ca.
Old 09-23-2025, 09:20 AM   #14
glennpm
glennpm's Avatar
Yes Mart, I didn't record my source and couldn't relocate it today. At the time I was looking for the sector shaft value and located the table.
Glenn
Rumble Seat’s Notes
Old 09-23-2025, 10:22 AM   #15
19Fordy
19Fordy's Avatar
Thanks Glenn, for posting that chart. Very helpful.
Old 09-23-2025, 10:25 AM   #16
petehoovie
petehoovie's Avatar
