Old 08-08-2025, 02:50 PM   #1
Andy
Default Pics of original 32 dash arrangement
This was for sale online. I had never seen pics of the original wiring and arrangement. That tube nut on the ammeter is like one I received with an ammeter. The wiring is interesting. I don't think that fuse wiring will work. Reason the car was scrapped?
Andy is offline   Reply With Quote
Old 08-08-2025, 03:56 PM   #2
Mart
Mart's Avatar
Default Re: Pics of original 32 dash arrangement
Good reference material, thanks.
Old 08-08-2025, 03:59 PM   #3
hueyhoolihan
it looks to me like the wire at the bottom of the pic #7 was once attached to the other end of the fuse.
hueyhoolihan is offline   Reply With Quote
Old 08-08-2025, 04:03 PM   #4
Brian
Brian's Avatar
And one way to bypass the resistor
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 08-08-2025, 05:39 PM   #5
petehoovie
petehoovie's Avatar
A RESISTOR MADE USELESS BELOW:
Old 08-08-2025, 06:29 PM   #6
DavidG
DavidG's Avatar
You would do better using the wiring diagram in the owners manual and the Service Bulletin (see attachment below) than these photos. Why is the lead to the dash light switch disconnected and the fuse block rendered useless?
Old 08-08-2025, 06:45 PM   #7
petehoovie
petehoovie's Avatar
Old 08-08-2025, 07:38 PM   #8
DavidG
DavidG's Avatar
Pete,
Thanks!
David
Old 08-10-2025, 07:39 AM   #9
Terry,OH
Terry,OH's Avatar
I found a hex brass tube nut on one of the gauges on my 34 but after some research found it belonged on the door window regulator as a stop. I don't see the tube nut in your photos.
Old 08-10-2025, 09:26 AM   #10
DavidG
DavidG's Avatar
Only used with the dual temperature/fuel gauge and then not until the '33s.
Old 08-10-2025, 12:16 PM   #11
Andy
I will share an oddity. The dash I just bought does not have studs for the gauges. It has threaded holes instead and very short round head screws. One without a lock washer was actually hitting the face and pushing it out some!
Old 08-10-2025, 01:54 PM   #12
DavidG
DavidG's Avatar
The reproduction panels lack studs as well.
Old 08-11-2025, 10:52 AM   #13
oldford
Thanks for the pics. I wondered what the holes in my dash support were for. So if the coil has a built-in resistor do you still need the resistor.
oldford is offline   Reply With Quote
