Old 08-03-2025, 06:53 AM   #1
3twinridges
3twinridges's Avatar
Default 8BA head gasket choice
Deck and heads are freshly milled. Have two choices, best gasket copper and best gasket graph tite. I like the looks of the copper, but also like the thought of being able to take the head off without breaking out a crowbar. Thoughts on best all around approach- good seal but also removable?
JB
3twinridges is offline   Reply With Quote
Old 08-03-2025, 08:00 AM   #2
kurt v
Default Re: 8BA head gasket choice
I just put grease on the graph tite gasket and heads come right off, NEVER will use copper cote spray again what a glued up mess.
kurt
kurt v is offline   Reply With Quote
Old 08-03-2025, 09:30 AM   #3
tubman
tubman's Avatar
kurt
I agree. If your heads leak after the installation of name brand gaskets and grease, there is a problem with the surface prep. I found out the hard way when I was young.
I also don't like copper gaskets, especially with aluminum heads. I just introduces another metal into an already complicated galvanic soup.
Old 08-03-2025, 11:05 AM   #4
mfirth
I have used Fel-Pro gaskets in two builds with no problems.
mfirth is offline   Reply With Quote
Old 08-03-2025, 11:22 AM   #5
3twinridges
10-4 on the Graph tite and grease! Appreciate it
JB
