Old 07-16-2025, 04:30 PM   #1
wga
wga's Avatar
Default Shoebox hood hinge bolts & wavy washers install ??
The wavy washer goes where? Between the bolt head and the hinge? Or
the hood and the hinge?
Thanks
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 07-16-2025, 04:32 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Shoebox hood hinge bolts & wavy washers install ??
Thanks
Old 07-18-2025, 10:44 AM   #3
flathead4rd
flathead4rd's Avatar
I don't see the washer in the picture. What am I missing?
flathead4rd is offline   Reply With Quote
Old 07-18-2025, 11:27 AM   #4
Cecil/WV
Cecil/WV's Avatar
Mine are on the bolt head.
Cecil/WV is offline   Reply With Quote
Old 07-19-2025, 11:19 AM   #5
Kube
Super Moderator
Kube's Avatar
Thanks
In '39 and '40 the washer was between the hood and the arm.
Not certain why it might be placed beneath the head of the bolt as I can't envision what use it would be there.
Old 07-19-2025, 11:24 AM   #6
19Fordy
19Fordy's Avatar
Follow Kube's suggestion as the wave washer helps prevent wear and wobble.
