Old 05-06-2025, 04:01 PM   #1
Kgkatyag
Default Air Filter Leak
Hi y'all, im working on this 1941 Super Deluxe. It has the oil bath air filter, but it seems to be leaking out of somewhere and getting oill all over the carb. Even with almost zero oil in it, its leaking.
I'm not super familiar with these, so I am hoping one of you could point out where the leak is coming from or have some suggestions.
Here's some pics of the air hat and my carb after I started cleaning it
thanks
Kgkatyag is offline   Reply With Quote
Old 05-06-2025, 04:14 PM   #2
1952henry
1952henry's Avatar
Default Re: Air Filter Leak
Clean the pan and put a little gas in it. Watch the bottom, the gas will show you the leak. Guessing a few tiny pin holes developed from water over the years. Just did this with an off topic air cleaner. The holes were very small.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-06-2025, 06:21 PM   #3
Kube
Super Moderator
Kube's Avatar
I'm guessing it'll be around that hillbilly weld on the bottom.
Do yourself a favor and find a replacement.
Old 05-06-2025, 07:41 PM   #4
ford38v8
ford38v8's Avatar
Ya think?
Alan
