Old 01-09-2025, 06:32 PM   #1
400A
Default 31 Eaton radiator cap
I have a choice 31 Eaton radiator cap, but it is unusable because the inside steel portion rotates within the stainless shell. Does anyone know of a reliable way to fix this?
400A is offline   Reply With Quote
Old 01-09-2025, 07:25 PM   #2
nkaminar
nkaminar's Avatar
Default Re: 31 Eaton radiator cap
Photos would help.
Old 01-09-2025, 09:43 PM   #3
J Franklin
J Franklin's Avatar
Jb-weld
Old 01-10-2025, 10:17 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
I also recommend that you add corrosion prevention to the cap.
File Type: jpg Radiator Cap Corrosion Prevention akb.jpg (62.2 KB, 57 views)
Bob Bidonde
Old 01-10-2025, 10:43 AM   #5
400A
The corrosion protection is a good idea. I use POR on my gas caps and the coating lasts a few years before it begins to peel. At least whatever peels off is likely caught in the spark arrestor so no contamination of the fuel.
Old 01-10-2025, 06:54 PM   #6
Bick in New Zealand
Bick in New Zealand's Avatar
I had a similar problem a while back. The difference was mine was on the car and I couldn't get it to release. I ended up drilling a small hole and putting a pin through it so that both parts were locked together. This was a mint Eaton, that had been restored. Now sitting on the shelf waiting for a solution.....
I am currently running a locking cap with a greyhound.
File Type: jpg 465799903_971078795057263_3458668775724177057_n.jpg (38.3 KB, 14 views)
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
