#1 |
I have a 35 Tudor 48 and would like to monitor both sides water temp and oil pressure any ideas the smaller the gauges the better as I don't want them to stick out like a sore thumb
#2 |
a thought if going after market 1 gauge 2 senders and a change over switch
#3 |
A lot of people mount these in the glove box. My set has a mechanical oil pressure gauge. Face of each gauge is only 1-1/2 in dia.
#4 |
I have mounted extra gauges in the passenger cowl panel. You can look over at them to see what is happening with the motor.
#5 |
TJ, Can you please post a photo of those "cowl panel" gauges. What size are the gauges?
Thanks. |
#6 |
#7 |
A good idea when using multiple gauges, is to "clock" them so the needle is vertical in the normal operating position. That way you can tell at a glance what needs more attention.
#8 |
#9 |
I have three mini gauges mounted in a panel under the center dash panel and find they are rather hard to read in a hurry. Have to take your eyes off the road for too long to decipher the readings correctly. I would go for the standard size 2 1/8" gauges if they can be fitted in. Regards, Kevin.
#10 | |
Very nice setup.
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#11 |
In my '32
Left to right: - Temp - Tach - Oil pressure - Voltage - Vacuum
