Old 12-27-2024, 07:19 AM   #1
V8 Bob
V8 Bob's Avatar
Default '40 Ford window regulator repair-Update
The handle crank shaft snapped on my coupe's left door regulator. I bought a commonly available repair kit , but it looks like the large main gear has to be removed to gain access installing the new cup rivets. I don't see any way to remove the gear other than grinding off the end of the spring stud on the back side of the main body. Problem is this replacement bolt/stud main assembly part is not included with the kit. I've searched for installing this repair kit without success, so I'm here hoping to find answers.
I have ordered a new set of complete regulators, but would still like to repair my original regulator. Thanks.
Bob
V8 Bob is offline   Reply With Quote
Old 12-27-2024, 08:52 AM   #2
fordyford
fordyford's Avatar
Default Re: '40 Ford window regulator repair
I have done it using "pop rivets"
fordyford is offline   Reply With Quote
Old 12-27-2024, 09:28 AM   #3
V8 Bob
V8 Bob's Avatar
I was also going to use pop rivets instead of the solid rivets in the kit, but there is not enough room to place one rivet because the gear is angled to the main frame and too close. The only option I see is removal of the gear, but destroying the assembly stud in the process.
Old 12-27-2024, 10:32 AM   #4
Karl Wescott
Karl Wescott's Avatar
Drake is still showing reproduction regulators available for the coupe. Might be a viable option. I am a dealer, as is Michael at Third Gen, etc.
Karl Wescott is offline   Reply With Quote
Old 12-27-2024, 02:58 PM   #5
V8 Bob
V8 Bob's Avatar
Thank you Karl for the offer, but I placed an order with Drake yesterday for the pair.
I still want to try and repair the regulators I have.
Old 12-27-2024, 08:22 PM   #6
325w
It’s not a hard repair. Pop rivet where you can then use a tube rivet in the other spot.
325w is offline   Reply With Quote
Old 12-27-2024, 08:43 PM   #7
V8 Bob
V8 Bob's Avatar
Have you performed this repair on a '40 regulator, as there is only just over 1/16" working clearance on the problem hole?
Old 12-28-2024, 02:09 PM   #8
V8 Bob
V8 Bob's Avatar
An update. I found if you remove the lower travel stop bolt, the main frame can now move away from the main gear, allowing full access to either side of the drive assembly. The only modification is removing about an 1/8" X 3/4" strip of metal at the end of the gear, above the stop bolt, to allow the drive gear clearance to re-engage the main gear.
Next is removal of the OE shaft pin and installing the supplied bushing for the new pin which comes pressed into the new shaft.
Original rivets were 5/32" and is what I'll use, either the supplied solid or on-hand tube style. With full access to the cup, pop rivets are not needed or the best option imo.
Bob
Old 12-29-2024, 10:53 AM   #9
Planojc
Planojc's Avatar
Default Re: '40 Ford window regulator repair-Update
Thanks for the update.
Planojc is offline   Reply With Quote
