Old 12-18-2024, 09:18 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default 1950 Ford Crestliner water pump
A friend called and said he sees antifreeze on the floor under his 50 Crestliner.
It has the original Flathead V8 in it. I have not looked at the car/engine yet.
Is a water pump readily available?? Or will I have to rebuild/? think there are two water pumps on his engine.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 12-19-2024, 12:28 AM   #2
nelsb01
nelsb01's Avatar
Default Re: 1950 Ford Crestliner water pump
First take a look.
Could be a hose clamp that needs tightening.
Otherwise, 50-51 water pumps are available. Some of the 'new' ones have improved bearings and impellers.
But there are several places to check before pulling a water pump.
nelsb01 is offline   Reply With Quote
Old 12-19-2024, 06:26 AM   #3
Mac VP
Mac VP's Avatar
We stock them as do most other vendors for flathead V8 engines. The pumps are the EAB type with the narrow belt pulleys. I think most of the offerings out there now will have the sealed ball bearings, carbon-ceramic seals, and the improved impeller design.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is online now   Reply With Quote
