Old 11-22-2024, 01:47 PM   #1
wickcopland
wickcopland's Avatar
Default 1939 Deluxe Radiator
What radiator do I need for my 1939 Deluxe with an 8BA?
Original radiator was lost when I took it to a shop I had used for 30+ years, closed and liquidated everything after the owners death. I dropped it there before I actually started working on the car. I bought one Cooling and Radiator Specialist about 2 years ago. It is too short and the top hoses don't clear the fan.
Thank you,
Wick
wickcopland is offline   Reply With Quote
Old 11-22-2024, 02:51 PM   #2
flatjack9
flatjack9's Avatar
Default Re: 1939 Deluxe Radiator
You will need a radiator for a 39 DeLuxe but will have to use a reducer on the top hoses.
Old 11-22-2024, 03:45 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
You could also use these water outlets made for the 8BA to use the larger hoses.
Ken/Alabama is offline   Reply With Quote
Old 11-24-2024, 12:43 PM   #4
deuce_roadster
deuce_roadster's Avatar
40 Fords use a 91A radiator.
Old 11-24-2024, 05:28 PM   #5
42merc
42merc's Avatar
If you are trying to use the 8BA fan set up, it won't clear the upper hoses.
Do a search here on how to adapt a crank mounted fan.
42merc is offline   Reply With Quote
Old 11-25-2024, 10:20 AM   #6
ScubaChief60
ScubaChief60's Avatar
If you are looking for a 'fine' replacement then speak to these folks. My original 89 year old radiator was not getting the job done... so they built a new one for me. It is great! Used it all through this past summer... cools great and is a 7PSI radiator.
https://usradiator.com/product/ford-...XpahfrgY_2lsOQ
ScubaChief60 is offline   Reply With Quote
Old 11-25-2024, 02:07 PM   #7
wickcopland
If only I had the last radiator that was in the car. I already have the larger hoses.
Does this radiator have upper supports.
Thanks
Wick
Old 11-25-2024, 03:18 PM   #8
mercman from oz
mercman from oz's Avatar
Radiator wanted for 8BA Flathead in wickcopland's 1939 Ford Deluxe
Old 11-26-2024, 05:46 AM   #9
ScubaChief60
The folks at usradiator make to order. Call and speak to them and I am willing to bet that they can fit just what you need. Now it seems it took a bit over a month for me to get mine but it fits well and works great!
