Old 11-13-2024, 11:08 AM   #1
Kelly Burns
Kelly Burns's Avatar
Default 47 Super Deluxe Clutch Catching Question
I have a '47 Super Deluxe, with a flathead V8 and 3 speed. The car is an unrestored driver quality, that I bought about a month ago. I've not started to dive into it this issue yet, I have not had the time, but thought I would ask for advice/guidance in advance.
The clutch and trans shifts smooth into all gears, no noticeable slippage or problems there. However when I push the clutch in, right before the pedal is completing to the floor, it kind of "catches" or acts as if it hits a detent in the stroke. When I let the clutch out, I kinda have to roll my foot to get it to release or come past the catch in the pedal stroke. What do you think it could be?
Kelly Burns
Kelly Burns is offline   Reply With Quote
Old 11-13-2024, 05:34 PM   #2
Bruce_MO
Default Re: 47 Super Deluxe Clutch Catching Question
Rubbing on the floorboard??? I’m nearing completion of a restoration of my ‘46 Mercury, and I had issues with the clutch pedal rubbing on the floorboard when the pedal was close to the floor. I couldn’t realign the floorboard to give more clearance, so I whittled on the floorboard a bit with a hacksaw blade to open up the hole on one side. When I pushed the clutch pedal in, there was an obvious scraping sound and a noticeable drag. Not sure if you have any slop or wear in the pedal bushing. That might be contributing to your issue.
Bruce_MO is offline   Reply With Quote
Old 11-13-2024, 05:54 PM   #3
1942deluxe
1942deluxe's Avatar
If it's catching on the floorboard most likely the bushings are worn out on the arm. Floorboard removal and the worst part is removing the snap ring the holds the arm in.
Just replaced the bushings on my 46. Also replace the foam rubber seals on the clutch and brake pedals while you are there.
Old 11-14-2024, 04:03 PM   #4
Kelly Burns
I'll check on both of those situations. The pedal action is smooth and easy without any rubbing sound tho.
Kelly Burns
Old 11-14-2024, 06:27 PM   #5
Kube
Super Moderator
Kube's Avatar
Did you crawl beneath the car when a partner operates the pedal?
I'm thinking the spring is either missing or is installed incorrectly and it (the spring) is either getting slightly caught or hitting something.
Old 11-15-2024, 03:59 PM   #6
Kelly Burns
Not yet, my son will be here this weekend, and having him operate the pedal was going to be my starting point. Thanks to you, I know the spring is a place start, thank you!
Kelly Burns
Old 11-18-2024, 02:04 PM   #7
Kelly Burns
We spent a little time yesterday diving into this. It is an odd problem, but not all that hard to fix. What is happening is there is about a 2" rubber hose/line where the fuel line transitions from along the frame, to vertically up the firewall. The elbow in the clutch pedal is hitting the top edge of the hose, pushing the fuel line to the side. When you let off the clutch the fuel line goes back into "place".
Kelly Burns
