Old 10-29-2024, 07:56 PM   #1
51shoeboxer
Default Unbalanced brake drum
My 1951 Ford convertible has a front brake drum that is 8 oz. out of balance. My Shoebox guru says to forget about it because the imbalance radius is so small, but I am concerned about it. What do you think?
51shoeboxer is offline   Reply With Quote
Old 10-29-2024, 08:11 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Unbalanced brake drum
Eight ounces? Eight?
That's a LOT. Are you sure it is eight ounces?
Eight grams perhaps?
Old 10-29-2024, 08:29 PM   #3
J Franklin
J Franklin's Avatar
If it is too unbalanced it will show up in the ride and tires.
Old 10-29-2024, 09:20 PM   #4
51shoeboxer
I used a magnet, bolts, and a postal scale to determine the imbalance; it was 8 oz.
Old 10-29-2024, 09:23 PM   #5
alchemy
alchemy's Avatar
I used JB Weld to attach a 1/4” chunk of steel to the outer surface of a 40 front drum on my car a few seasons ago. Hasn’t fallen off yet.
alchemy is offline   Reply With Quote
Old 10-29-2024, 09:30 PM   #6
51shoeboxer
That's the sort of answer I was hoping for.
Old 10-29-2024, 10:04 PM   #7
cas3
I would grind off whats needed if you have a way to static balance them, like on the spindle with dry bearings set loose.
Old 10-29-2024, 10:25 PM   #8
rich b
rich b's Avatar
Take it to shop where they balance engines; should be able to fix it right up.
rich b is offline   Reply With Quote
Old 10-30-2024, 07:53 AM   #9
Kube
Super Moderator
Kube's Avatar
Bingo!
I'm still trying to comprehend an eight ounce out of balance condition. That's huge!
Old 10-30-2024, 08:30 AM   #10
Terry,OH
Terry,OH's Avatar
Any engine rebuilder should be able to guide you to a balance shop.
Old 10-30-2024, 11:09 AM   #11
flatford8
flatford8's Avatar
Originally Posted by Kube View Post
Bingo!
I can’t believe something isn’t visible…..8 oz doesn’t sound like a lot…until you call it “half a pound”!….on that small of a diameter …..any tires I’ve balanced take 2-4 oz…..but the diameter is so much more….can you show us the method for checking it that you’re using?………Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 10-30-2024, 11:33 AM   #12
Kurt in NJ
Kurt in NJ's Avatar
How much oversized is the drum? might be better to buy new instead of paying to have it balanced
Old 10-30-2024, 11:47 AM   #13
tubman
tubman's Avatar
This makes a lot of sense. Why put any money into an obviously problematic brake drum? $90 at Rock Auto.
tubman is online now   Reply With Quote
Old 10-30-2024, 01:37 PM   #14
rich b
rich b's Avatar
Bingo!
He didn't mention it; but I looked up new '51 front drums and they seem to be obsolete in the regular replacement parts market.
I found repop drums listed that look to be Argentina full cast iron.
I have seen one of those; but for an F-1, that machined "off center" which leaves one side of the drum thicker than the other. Could very well be way heavy on one side.
Old 10-30-2024, 04:47 PM   #15
flatford8
flatford8's Avatar
Comment Deleted
Old 10-30-2024, 06:16 PM   #16
Krylon32
Before I became a Boling Bros dealer I was using Lincoln drums that were foreign made from another manufacturer and out of balance drums were common. Fortunately I only sold maybe a dozen pairs of them on customer chassis before going to the Boling USA made drums. No further problems. I did my best to help the customers with the bad drums. Most of them had them spin balanced with the tire and wheel on the car.
Krylon32 is offline   Reply With Quote
Old 10-31-2024, 12:46 PM   #17
Tim Ayers
Bingo!
I agree. 8 Oz spinning around out of balance must be causing one heck of a vibration.
