My 1951 Ford convertible has a front brake drum that is 8 oz. out of balance. My Shoebox guru says to forget about it because the imbalance radius is so small, but I am concerned about it. What do you think?
Super Moderator
Eight ounces? Eight?
That's a LOT. Are you sure it is eight ounces? Eight grams perhaps?
If it is too unbalanced it will show up in the ride and tires.
I used a magnet, bolts, and a postal scale to determine the imbalance; it was 8 oz.
I used JB Weld to attach a 1/4” chunk of steel to the outer surface of a 40 front drum on my car a few seasons ago. Hasn’t fallen off yet.
I would grind off whats needed if you have a way to static balance them, like on the spindle with dry bearings set loose.
Take it to shop where they balance engines; should be able to fix it right up.
#9 | |
Super Moderator
I'm still trying to comprehend an eight ounce out of balance condition. That's huge!
Any engine rebuilder should be able to guide you to a balance shop.
I can’t believe something isn’t visible…..8 oz doesn’t sound like a lot…until you call it “half a pound”!….on that small of a diameter …..any tires I’ve balanced take 2-4 oz…..but the diameter is so much more….can you show us the method for checking it that you’re using?………Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
How much oversized is the drum? might be better to buy new instead of paying to have it balanced
#13 |
#14 | ||
I found repop drums listed that look to be Argentina full cast iron. I have seen one of those; but for an F-1, that machined "off center" which leaves one side of the drum thicker than the other. Could very well be way heavy on one side. |
#15 |
Comment Deleted
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP Last edited by flatford8; 10-30-2024 at 04:51 PM. Reason: Reread last post |
#16 |
Before I became a Boling Bros dealer I was using Lincoln drums that were foreign made from another manufacturer and out of balance drums were common. Fortunately I only sold maybe a dozen pairs of them on customer chassis before going to the Boling USA made drums. No further problems. I did my best to help the customers with the bad drums. Most of them had them spin balanced with the tire and wheel on the car.
#17 |
