Old 10-24-2024, 08:09 PM   #1
Cave Creek Coupe
Default Leaking gasket on 39 Ford Coupe
Hello friends,
I’m trying to identify this gasket on a 39 Ford Coupe Deluxe that appears to be leaking fuel.
Cave Creek Coupe is offline   Reply With Quote
Old 10-24-2024, 11:07 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Leaking gasket on 39 Ford Coupe
Look up under the fuel pump with a mirror —- most likely the fuel pump diaphragm is leaking. Even for those gaskets are leaking fuel instead of oil the diaphragm would have to be leaking.
Old 10-25-2024, 10:22 AM   #3
Kube
Super Moderator
Kube's Avatar
Spot on advice...
Old 10-28-2024, 06:20 PM   #4
Cave Creek Coupe
After careful examination, gas is coming out of this little hole in the fuel pump. In the 2nd picture, one of the screws appears to be stripped. Can’t find the part anywhere. The oil cap screws into the top and fuel pump is mounted on the side.
Old 10-28-2024, 06:25 PM   #5
tubman
tubman's Avatar
For a temporary fix, get a longer screw and a nut.
Old 10-28-2024, 07:57 PM   #6
Zeke3
Zeke3's Avatar
Gas leaking out the small vent hole is an indication the pump diaphragm is beginning to leak.
Zeke3 is offline   Reply With Quote
Old 10-28-2024, 08:38 PM   #7
Cave Creek Coupe
I have a rebuilt kit on order. Thank you for the advice.
